e-fan harness
Old Sep 22, 2007 | 03:17 PM
bluecajun5.3's Avatar
11 Second Truck Club
Default e-fan harness
who makes them?
i need one for some ls1 fans to put on my friends truck.
we're going to be using the pcm to control them.
thanks,
lance
Old Sep 22, 2007 | 03:23 PM
nightrunner's Avatar
Mr. Obvious
nelson performance
might pm DLH2006
Old Sep 22, 2007 | 04:06 PM
xlcooplx's Avatar
got mine from DLH2006. no problems here.
Old Sep 22, 2007 | 04:50 PM
Mark Johnson's Avatar
Yup- DLH2006. I just ordered one from'em less than 2 minutes ago.........
Old Sep 22, 2007 | 05:48 PM
tarinitup's Avatar
9 Second Truck Club
nelson's worked good for me. probably a matter of price and availability, I'm sure either will be fine.
Old Sep 22, 2007 | 08:41 PM
thanks.
i knew someone on here mad them.
derek, hit me up with a PM.
Old Sep 22, 2007 | 08:53 PM
Derek @ EDO's Avatar
FormerVendor
PM sent Lance.
Old Sep 22, 2007 | 10:05 PM
PathfinderJr's Avatar
Was a soft-start solution to when the fans turn on high ever found? Do these harnesses (DLH's and/or Nelson's) have said feature?
I think I remember folks talking about this and how they wanted to try and avoid the sudden shock to the system.
Old Sep 22, 2007 | 10:06 PM
back at you derek!
Old Sep 22, 2007 | 10:14 PM
FormerVendor
My harness does not have a "soft start" feature, the fans will kick on low to begin with so there is no "shock" to the system. My harness uses power from the fuse block and uses low voltage wiring and grounds for activation.
I have yet to have a problem with my setup or anyone that has used one similar.
Derek
