dyno'd -> 409hp / 540 ft/lb torque
Old 12-24-2004, 04:57 AM
sfj
yeah i say bigger springs and another thing on a FI motor (not so much with turbos) but the more you dyno it the hotter it gets and FI motors do not like heat. it should not make as much of a difference because of winter time but might be another reason you dynoed down from your first. i bet if you gave it another run it would have done the same thing again lost a little power
Old 12-24-2004, 08:38 AM
retsell's Avatar
now i need to find some springs.
Old 12-24-2004, 08:46 AM
Flyer's Avatar
THat's some rpetty good numbers! On the back of the cam should be some numbers. If it was a GM cam it would have had a 3d bar code looking thing laser etched in, CompCams have a number with the letters HR in it. If you give them those numbers they will tell you exactly what the cam is.
If it was a 216/220, stock springs wouldn't be any good for that, trust me. LS6 springs are pushing it, but the 918's will be fine.
Old 12-24-2004, 09:06 AM
Sport Side's Avatar
@ what rpm did you make 540 ft lbs?
Old 12-24-2004, 09:44 AM
ranwalk's Avatar
that torque number is crazy
Old 12-24-2004, 10:39 AM
10 Second Club
04BlackGmc's Avatar
Very big numbers i like!
Old 12-24-2004, 11:11 AM
BigTex's Avatar
On a dynojet, the numbers would be bigger. Of course the M6 transmission doesn't hurt.
Sweet numbers.
Old 12-24-2004, 11:26 AM
TigerFan187's Avatar
I would for sure do some springs. I put in some K-Motions butt he 918's are nice as well! That suck about teh audible det! Good Luck man!
Old 12-24-2004, 09:50 PM
retsell's Avatar
33XX, I left the graphs there on accident, i'm gonna try and get them to fax them to me on monday.
Old 12-24-2004, 09:51 PM
retsell's Avatar
Thank you.
Quick Reply: dyno'd -> 409hp / 540 ft/lb torque
