DYNO results + Cam?
DYNO results + Cam?
Hi all today i went to a local speed shop with my 2012 chev 1500 6.2 Stock did a few chassis dyno pulls, stock averaged 343tq 328HP. I had purchased a Hypertech max programmer awhile back so i installed the premium tune and averaged 355tq 341hp. at a 12.6 to 13.0 AFR at WOT. Then i let the shop do a custom tune and they got around the same tq and +1-2 more hp. i figured they could get more the only difference was there tune had no kr where the hypertech had a few spots where i was seeing 4-6 deg kr at certain spots. Let me know what you guys think?
My 2nd ? is i have a 98 s10 with a 00 truck 5.3 installed with 4L60E with 3.73 gears and a TB converter. I asked them about a cam rec and they suggested a custom grind with 230/224 duration 590/540 lift on a 114 lsa. reverse grind PEP dual valve sprins PSK-658-8-7 and 7.400 pushrods. can someone explain to me why they would suggest this. the truck is a daily driver and weekend drag truck and addition info would be great thanks. i would be dyno tuning for the cam install aswell any ideas on how much increase this would give me i have never dynoed the truck just basic tuning on hp tuners best time at track was 14.1 with slicks time was ran with stock TMBX truck stall thanks all!!
I talked to texas speed today and they recomended that i used a 220 220 581 581 114lsa or a 224 224 581 581 112 lsa can anyone chime in here to help me decide i will be installing a 3200 stall if i go with the 224 224 otherwise i will keep my TB converter with the 220 220 thanks for any input
