DYNO RESULTS 2014 Cam, Headers, Exhaust
Old Mar 27, 2021 | 03:47 AM
IIGW's Avatar
5 Year Member
Default DYNO RESULTS 2014 Cam, Headers, Exhaust
2014 5.3 80k miles, recently had a TX ‘stage 2’ cam, lifter, AFR delete, CAI, 1 7/8 long tube headers, performance Y Pipe, high flow cats, into a single ‘high performance’ borla system that is dumped before the axle, installed and dyno tuned.
The rest of the vehicle is stock. Stock 17 inch wheels/tires, gearing, trans, convertor etc. The tune said the convertor should be swapped to a looser one due to the cam. I don’t know the stock stall, but will in the very near future, switch to a 2200/2500 stall, and have the trans gone through while it’s out.
The tuner said he experience vibrations at 105 mph, so he kept it locked in 3rd gear and didn’t go any faster as these trucks are known to let their drivelines go when abused.
To compensate for this, he stated, “add 30 hp/tq to the entire curve..
Granted, this is not a race truck, just a nice daily driver with some extra power.
But, does this dyno chart look correct, or is there issues?
The tuner, is a well-known and highly recommended, so I don’t think he did the job incorrectly.
Another issue, is, the shop doing the work for me towed my vehicle there and back for the tuning, but I wasn’t provided anything other than this dyno sheet. I don’t know if he changed shift points, adjusted throttle pedal, what octane it’s tuned for, literally nothing. No, I have not contacted the tuner yet, but I will to see about getting this information.
Old Mar 27, 2021 | 10:23 AM
ZO6Ted's Avatar
I think I was stalling 2300 stock iirc but that cam may not though if there is a loss in low end. I'll let others comment on the rest. Now add a blower lol and congrats on a fun truck.
Old Mar 28, 2021 | 01:11 AM
IIGW's Avatar
5 Year Member
:bump: anyone?
Old Mar 28, 2021 | 06:24 AM
3wide's Avatar
You have two threads going so don't expect anything the other thread has already mentioned.
Old Mar 28, 2021 | 06:42 AM
IIGW's Avatar
5 Year Member
One thread is my entire build thread. I posted the results.
This thread is only related to the dyno results. Surely, someone has put a cam in a 2014 5.3 and knows if the results are similar or completely off.
Thanks for the help you have provided, much appreciated.
Old Mar 28, 2021 | 08:07 AM
smokinlmm's Avatar
That seems about right, usually about 90 to 100 hp gained from cam depending on grind. Power band will be predicted by cam specs. Did the builder provide them?
Old Mar 28, 2021 | 08:35 AM
3wide's Avatar
Well, I don't know your gear ratio, regular cab-extra-crew cab. I don't know if you filled the tank with 93 octane or other before the tune. Depending on you body type will determine if you need a stall (weight of truck). My wife drives a 2012 Yukon Denali with a 6.2 and a Texas Speed Cam and I don't need a stall= it roasts the tires shifting all the way through the end of 2nd gear. I know you have the 5.3 engine but since you are drive shaft limited for top speed you should stop light race real well in that truck.
Old Mar 28, 2021 | 08:37 AM
IIGW's Avatar
5 Year Member
I bought all the parts. I'm just in another country, so I had a local shop do the work, and a reputable tuner do the tuning. Thanks for the information, from my research it does seem right on point.
I'll post more once I am able to talk to the tuner for what he did. I'm just hoping he didnt tune it for grandma.
Old Mar 28, 2021 | 09:04 AM
smokinlmm's Avatar
The newer trucks are a bitch to tune. Be patient with the tuner.
Old Mar 29, 2021 | 12:20 AM
IIGW's Avatar
5 Year Member
patient? he's done. what's to be patient about?
