Dual Stage Boost Control ?
Old Jul 30, 2004 | 08:06 PM
OLD BULL's Avatar
Default Dual Stage Boost Control ?
I'm still torn on the decision between the Whipple or the STS. I like the way you can run the dual stage boost controller on the STS then at the flip of a switch run a higher boost and activate alcohol injection. Is there a way one can do this with the whipple.
Old Jul 30, 2004 | 08:16 PM
parish8's Avatar
single digit dreamer
no, you have to swap the pully.
you can get more than a duel stage control for the sts kit. you can get an electronic boost controler that will let you do any kind of boost control you want. you can base it on rpm or mph or gear or time and it can have more than 2 setings. my controler has 4 presets, i can program each preset and then at the click of a button go from one preset to the next. if you are traction limited then some of that other stuff would be cool but in my case i want the boost as fast as i can get it so the mph/rpm/time based control does me no good.
chopperloco
Jul 10, 2016 10:45 PM
greedygenius
Sep 3, 2015 06:51 AM
KyleW707
Jul 29, 2015 08:17 AM
lxcoupe
Jul 15, 2015 10:03 PM
