dual cut outs
Old Apr 14, 2006 | 08:04 PM
adrenalinep's Avatar
Default dual cut outs
My bro has a sc 4.8 w/ longtubes, true dual w/ no cats and was wanting to install dual cut outs before the mufflers. Does anyone have this setup and did it help performance ? thanks
Old Apr 14, 2006 | 08:16 PM
2004SSS's Avatar
im o you wont really get any performance, and maybe in his case may lose some bottom end because of such low backpressure. Cutouts are more for a coolness factor. It also depends on the application though!
Old Apr 15, 2006 | 12:41 AM
he already seems to have great flow, cut outs really arent needed
Old Apr 15, 2006 | 12:51 AM
onebadrubi's Avatar
I have lt's to cutouts...then dual 2.5" into x pipe then into two flowmasters. Cutouts might help on the top end a little bit....I hope to find out tommorow exactly...goin to the track.
Old Apr 15, 2006 | 01:11 AM
CrabhartLS1's Avatar
Guys it's an SC 4.8 with LT's. He's obviously tuned. No worries with the "backpressure" BS.
That being said the cutouts are completely for loudness, not for performance in this case, LT's and an ORY flow well enough that you could run the stock muffler and still only loose about 7hp.
What's he running, flowmasters? If he's running bullets, 1 chambers, or ultra flows, cutouts won't be worth it. Sound or power wise.
However, two cutouts directly after the headers would be the ****.
Old Apr 15, 2006 | 08:58 AM
2 chamber flow masters
Old Apr 15, 2006 | 12:44 PM
v8
17,16,15,14,13,12,11 Drvr
I picked up 3/10's with the cutouts right after the asm long tubes, daily driver is longtubes dual in dual out imco muffler.
Old Apr 15, 2006 | 12:50 PM
Sport Side's Avatar
Yep.
I picked up 1 tenth and 1 mph from dual cut-outs with my bolt on truck.
Back to back runs. Same 60'.
13.9 @ 95 to a 13.8 @ 96
But, you guys stick to what yall do to go faster.
Old Apr 15, 2006 | 07:27 PM
I would recomend a single cutout over a dual. But thats my opinion.
Old Apr 16, 2006 | 12:14 AM
thats pretty good numbers and a helluva lotta noise...
