Does ANYONE have high-flow cats for Silverado?
Coming soon: 05 e-fans, 34" radiator, and 160* SLP stat, Yank TT2600
Thanks!
Check out this website for the Magnaflow y-pipe. It costs about $800.
http://www.fle-online.com/MAGNAFLOW/.../directfit.htm
Check out this website for the Magnaflow y-pipe. It costs about $700
Originally Posted by buktseat
Hey Bud, do you know what's involved in converting the engine driven fan in our trucks to electric? Are you going with a factory-bought control system of some kind or something aftermarket? I've been thinking about doing an e-fan conversion, too, but I've had reliability with similar conversions on past projects. Also, do you know what it's gonna cost you?
Thanks!
Thanks!
You could do basically the same thing and spend a little less if you use ls1 fans, then you wouldn't need to swap the radiator. Just need to get a custom tune and harness, and have the tuner set the PCM to turn on the fans.
creederado did a great write-up on his 05 e-fan install:
Creederado's 05 E-fan Upgrade
(I've referred to this thread many times
Also, what do you folks have to say about the flexalite fans that end up being a bit cheaper? Any thoughts? And where might one get hold of the LS-1 fans you mentioned that don't require a radiator upgrade? Is there any reason to think that these would be inadequate?
I really appreciate all the info! Thanks!
Originally Posted by Allgonoshow
you won't find a direct fit kit for the truck. Gm cats flow as good as anything else so a salvage yard set would be a good bet.
You could have a muffler shop weld in replacement cats to the existing y-pipe and you
magnaflow convertors, but if it was mine i'd try and find a used low milage oe pipe.
david
david
I bought the highflow cats from magnaflow,which are carsound cats,had them for 6 mths and no issues i just had them welded in i paid $77 per cat so save yourself $500 dollars.And the factory cats are junk my drivers side completly plugged and rattled.
