dod delete help and turbo 5.3 help 07 rcsb
I finally joined pt.net always has good info but I camt find the specific info im looking for. I've been searching for awhile now and I can't figure out what I want. I have read that I need this and that for the dod deletes I see the premade kits and they are all different so I'm asking for an accurate list, I feel that shouldn't be to much to ask for. Next I would like to know what fuel pump would be good for the stage 3 trick performance turbo kit (76mm) I was gonna run dual but I read the the stock pump is good to 500hp. Is this true? lastly my cam, Idk what cam to run I know turbos and choppy cams don't work together but I've heard a few that seem pretty choppy but I'll be happy with just suggestions. I'm planning on running about 15psi on a stock 5.3 07 rcsb I have my 4l80e ready to be installed . Anything helps this is an open thread if you think my build sounds dumb tell me and if it strikes your fancy let me know but apparently I suck with google so anything will help.
Thanks alot
Dillon
Thanks alot
Dillon
Heres a dod delete list.
https://www.performancetrucks.net/fo...t-list-493773/
As for cam get with stock4.8 is his screen name. His isky triple 12 cam has given people good results. We are running a 5.3 flex fuel truck at 11 pounds of boost on 60# injectors with no issues.
Choda
Jan 22, 2026 02:03 PM
MattOKC
Aug 18, 2015 11:30 AM
