Do these spark plugs look odd?
Old Jun 19, 2007 | 01:18 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Do these spark plugs look odd?
Not sure if they are telling me something. What do you guys think?
Old Jun 19, 2007 | 01:51 PM
Tootall's Avatar
orange funk from some bottle additive?
Old Jun 19, 2007 | 03:02 PM
1SlowHoe's Avatar
That what my first thought as well but, I cant remember adding anything. I may have added an octane booster a few months ago trying to figure out a KR issue. I'm not 100% positive I did though. Even if I did, it was months ago. I'm running pretty fat right now while in boost, like 10.8:1, so I was thinking they were a little fouled from to much fuel. I'm getting on the dyno Thursday to fix the AFR so thats why I was doing a plug change.
Any other suggestions on what may have caused my plugs to look this way?
Old Jun 19, 2007 | 03:46 PM
CHEVRACER83's Avatar
JUST SWAP EM AND AFTER A WEEK CHECK THE NEW ONES...
YOU CAN SEE THE SMALL CARBON ON THE ELECTRODE FROM YOUR RUNNING A LITTLE TOO FAT...
Old Jun 19, 2007 | 03:48 PM
They Dont Really Look "bad" Though.... Maybe A Little Rough.... But I Bet If You Lean It Up A Little And The New Plugs Will Be Clean As A Whistle...
Btw Ive Seen A Few Sets Of Ngks Turn A Orangish Brown With A Great Tune. In A New Ls7 We Were Palying With Had Nothing Really But I/e And Tune, And The Plugs Turned An Orangish Brown...
Probably Nothing To Worry About
Old Jun 19, 2007 | 04:11 PM
Tootall's Avatar
2nd one from the right is a little dry and crispy - injectors ok?
I seafoamed my old engine before I pulled it, and my plugs were a funky orange just like those. I hit `em with the wire wheel, some cleaned up, and others didn't flinch.
Old Jun 19, 2007 | 06:23 PM
Phantom's Avatar
11 Second Club
my stock plugs looked like that when i took them out to put my tr6's in...i never added any additive. I was curious as well
Old Jun 19, 2007 | 09:23 PM
budhayes3's Avatar
PT's Slowest Truck
From what I can tell with my screen settings, those plugs look pretty good. You're supposed the want a nice tan color to them, but I've been noticing a reddish,orange more and more. May be detergents in the gas. The one plug that looks a little rough is the 2nd one from the right in the 2nd pic....is it possible that cyl is running lean and/or you're experiencing detonation?
Old Jun 19, 2007 | 10:55 PM
1SlowHoe's Avatar
I get KR all the time. Almost always with the converter locked, going 55mph, then I give it 30% or more throttle and instant KR with no downshift. Sometimes the KR is in the 7.x* range. I actually heard it today for the first time. I usually don't hear any audible knock when I get the KR on the scanner. The part that kills me is when I get it here are the conditions:
IAT's below 100*
Timing is around 15*
I'm at 0-1 psi of boost
AFR is between 10.8 and 11.2
These are not conditions in which KR should be an issue.
At WOT I get 0 to .2 degrees of KR and thats rare. I'm hoping the tuner can work this out Thursday.
Old Jun 19, 2007 | 11:03 PM
Wheatley's Avatar
Truck Sponsor
With the way the fuel is now days,it is not uncommon for them to have a redish tint to them.Not sure if yall have ethanol there but here we have up to 10% and the additives can cause that some.
