do some tranny work
Old Jun 5, 2003 | 02:11 PM
homeskillet's Avatar
Default do some tranny work
i want my truck to shift better so i was thinking of doing a vet servo. i think this will help out my 1-2 shift i hope. can some of your guys help me out here as to what you think i should do. also could i get some prices on how much i will be spending on what i choose to do also where to get every thing from. by he way i have a 99 gmc 4 wheel drive i dont know tranny i have. any help would be great. i want to be able to
Old Jun 5, 2003 | 04:33 PM
Hit Man X's Avatar
Default Re: do some tranny work
If you have an automatic it is a 4L60E 4 speed OD.
A 'Vette servo is a pretty popular upgrade for the 700R4/4L60E trannies. They are pretty cheap at about $15 for just the servo and install is pretty straight foreward or around $40 to pay someone. The gains will be very slight with just a servo upgrade alone. A few have gone to billet aluminum servos as they hold the 2-4 band in the trans much better than the 'Vette servo.
The '99 I used to have shifted really crappy. I installed a TransGo shift kit and was day and night difference in shift quality, that was with the stock 2-4 servo. The TransGo is usually around $100 for the kit and about $150 to install. I'd go that route for a far cleaner shifting trans.
It really depends on how much you are willing to spend and if you want to get into the case of the trans... nothing external bolt in or on (like servos or pressure increasers) will fix the setup of the factory valve body.
A good setup would be a TransGo and the 'Vette servo. Very nice shifts and reasonably priced.
Another thing that may rise an eyebrow would the the effect of Torque Managment, it pulls timing and slows your truck's power and shift speeds. I would look into a Diablo Predator programmer for power, raise the really low shift points on the '99's, and to remove or lessen Torque Managment.
Parts from Chad at... www.kdsperformance.com
Shift kit - http://www.kdsperformance.com/tranhigpersh1.html
'Vette Servo - http://www.kdsperformance.com/corser700r44.html
Billet 2-4 servo - http://www.kdsperformance.com/supser700r44.html
Billet OD servo - http://www.kdsperformance.com/ovsupser704l.html
Hope that helps,
Eric.
Old Jun 5, 2003 | 08:04 PM
this is axactly what i wanted to hear some options so i am thinking of going the servo route right now what is the deal with so many servo packs there is the vete 'Vette Servo Billet 2-4 servo Billet OD servo why so manny isnt there just one servo or are there manny? why is the vette servo so cheap?
Old Jun 6, 2003 | 10:39 AM
Hit Man X's Avatar
The regular 'Vette servo is a factory piece, they are plentiful hence making them cheap.
The trans has on the passanger side of the case a set of apply pistons called servos. They apply and put pressure on the 2-4 band in the trans. There is an intermediate servo (the 'Vette one is) and an OverDrive servo.
Your truck only has two servos. All the ones I listed are options to go with.
The billet ones are made of aluminum and hold far more than the stock 2-4 servo or the 'Vette servo.
Jakejack
Jan 8, 2024 10:44 PM
Oobray
Jun 13, 2022 03:38 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
Chiphead
Jul 13, 2015 10:16 PM
