Do new lifters need to soak in oil for awhile?
Old Jun 29, 2011 | 05:37 PM
  #21
JFOLM's Avatar
A lot of that derives from the old hydraulic flat tappet lifters though.
Old Jun 29, 2011 | 05:49 PM
  #22
Mangled03gmc's Avatar
Baltimore Whore
I've always soaked em...IIRC, I recently read on Crane's website that it isn't totally necessary but is good practice, as a few have mentioned here
  #23
06murder's Avatar
dont forget to clean ur pushrods too
Old Jun 29, 2011 | 07:02 PM
  #24
hirdlej's Avatar
I just did a head swap on my truck and put new lifters in. I took some of that red and gooey clevite bearing lube and just wiped the lifters down along with packing the needle bearings with the stuff. Put everything together and fired it up. Quiet as could be and had instant oil pressure. Remember, in an LS engine, the lifters get oil FIRST before the rotating assembly. I had oil pressure within 2 seconds of starting my truck with my high volume pump. Don't worry about it, you'll be fine
Old Jun 29, 2011 | 08:33 PM
  #25
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I dont soak them anymore. Drop the lifters in, pour some oil over them and throw the heads on. Prime the engine with the coil packs unplugged them start it up. Youve got 60+ psi of oil pressure shooting the through the oil galley do you really think that little bit of oil that can actually seep in there by just being static in an oil bath really does anything? Pouring oil over the lifters once installed will give them enough oil to lubricate the lifters during initial startup. In my experience very little oil actually gets into the body of the lifter due to the small orfice in the lifter body. Remember air bubbles have to make it out of the lifter body through the thick oil so the oil can take its place.
Theres a reason why gm dealers have a priming apparatus, I believe moregrip has one. Ive always just pulled the coil pack plug, turned it over for a few seconds and started it up.
Old Jun 29, 2011 | 10:11 PM
  #26
LsF-150's Avatar
I've always done it with the fuel pump relay removed, dont like the idea of the injectors spraying raw fuel into the cylinders, especially on a fresh engine. I also like to prime with the plugs out on crank driven oil pump engines
Texas5.3_1251
Mar 5, 2016 08:10 PM
Dezmo
Sep 9, 2015 02:09 AM
Brandonlflr12
Sep 8, 2015 09:01 PM
11MPG
Sep 8, 2015 04:52 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
