Do I need larger injectors?
Old Oct 15, 2014 | 11:29 AM
Justhereforinfo's Avatar
Default Do I need larger injectors?
I have a 5.7 ls1 with 243 heads and a custom cam. Cam is low duration, specd for truck use. Im using my stock 2003 4.8 truck intake/exhaust/tb/maf/injectors.
I think my stock injectors are 26#. With the stock intake and exhaust, I expect to make around 330-350whp through the auto. Stock converter and limiter.
Will these 26# injectors support my fueling needs?
Old Oct 15, 2014 | 11:58 AM
black00chev's Avatar
Slowest turbo build ever!
They should be... I think my '00 5.3 has only 19# stock and with my current setup they are running at 93-95% IDC peak. So you should be good, but only one way to really know for sure!
Old Oct 15, 2014 | 08:12 PM
If your 19s are maxed at 300whp, my 26s will probably be maxed at 330-350whp. Duty cycle shouldnt be over 85% right?
Old Oct 15, 2014 | 08:32 PM
Ideally yea no more than 90% but I have no issues. Im also right around 330hp now with a good tune, LTs and ory.
And I could be wrong about what size my stock injectors are. If mine are the 24-26# injectors then you might want to look into some in the 30something range.
Old Oct 16, 2014 | 08:48 PM
Thats good news. I should be good then. Thanks
OHsixLS3
Sep 25, 2015 11:20 AM
jroctpb
Sep 16, 2015 09:05 PM
rednekferlife101
Sep 14, 2015 05:27 PM
lxcoupe
Sep 2, 2015 12:58 AM
