Disappointing HP numbers
Old Apr 7, 2021 | 01:18 PM
arthursc2's Avatar
Given how much you don't know about the number they gave you, I would not be concerned/upset/worried/fretting about it. Put her on a dyno to maximize power and get a real number (with some variance of its own)
However, 500 was not ever going to happen, I'm sorry to break your heart
Old Apr 7, 2021 | 01:51 PM
RedXray's Avatar
100% Redneck
Originally Posted by terravast4
I think thats great N/A numbers considering drivetrain.
I agree probably be around 415 to 420ish in a manual f-body, 440ish with a free flowing exhaust system.
Old Apr 7, 2021 | 02:22 PM
darkirish63's Avatar
Get rid of the shorty headers and add LTs. You'll pick up 20-25HP, easy. Two things that restrict these builds; air in and air out. The TBSS intake is plenty for your build but, those shorty headers are just the same as stockers...get rid of them.
Old Apr 7, 2021 | 03:26 PM
TXsilverado's Avatar
those numbers seem decent to me given the combo. The only calculators you should trust are Dynos (somewhat) and Drag times. What did you do with those square port heads? You can throw them into my trash can
Old Apr 7, 2021 | 04:00 PM
Jonblarc7's Avatar
The app is just uses a GPS signal. It's just like a Dragy with out the box. You just use your phone. I heard it can be paired with a GPS device through your phone to make it more accurate.
Old Apr 7, 2021 | 05:16 PM
arthursc2's Avatar
If it doesnt know the weight, how is calculating the hp? If the entered weight isnt accurate, how does it know?
HP is unit of work. The math needs to know how much work (weight moved) is being done in a certain amount of time (rpms climbing/mph increasing)
Old Apr 7, 2021 | 05:19 PM
FFDP's Avatar
Maybe he's talking about the calculated engine horsepower in the scanner. You can log that on just about any vehicle.
I use that channel all the time on the DI engines. I need the peak engine horsepower/torque very similar to predicted and calculated engine torque/horsepower.
Old Apr 7, 2021 | 05:42 PM
arthursc2's Avatar
so its based on engine size and fuel load?
Sorry for the redundant questions, I am not a tuner/ user of HPT, just trying to understand whats happening here
Old Apr 7, 2021 | 06:06 PM
timharber's Avatar
Yes the number cam from the scanner. Is it remotely accurate?
Tim
Old Apr 7, 2021 | 07:11 PM
swathdiver's Avatar
5 Year Member
When I was a youngster, we weighed our cars at the track and then made three or four passes before making any more changes. After those runs we could mathematically calculate how many horsepower we were putting down to the rear wheels through the traps. Small, high stall converters certainly felt better off the line but nearly always resulted in lower elapsed times and a loss in horsepower through the traps.
Curb Weight*((MPH*0.00426)^3)
