Differential ???'s
Old Apr 27, 2004 | 10:41 PM
99Silver6.0's Avatar
Default Differential ???'s
Detroit TrueTrac vs Eaton LSD. Which would be better suited for my truck???
Old Apr 28, 2004 | 06:28 AM
one03sierra's Avatar
Formerly one92rs
Talking
i really like my new eaton. it is a sweet unit.
Old Apr 28, 2004 | 07:58 AM
Deckhand's Avatar
ditto, but i guess you could try the locker and see how it works. how much are they?
Old Apr 28, 2004 | 08:33 AM
Love my Detriot.
Old Apr 28, 2004 | 09:25 AM
Hit Man X's Avatar
Eaton's gonna be smoother for a street bound vehicle. You can also updrage the preload springs to 800lbs (up from 400lbs) for an even heavier grab. They are black springs.
There's lots of peeps local to me running Eatons well into the low 11/high 10 sec range w/ 800lbs springs. They don't bind on turns and grab great.
Old Apr 28, 2004 | 12:10 PM
Dont you think 800lb springs will act more like a spool in a RCSB truck due to there being little weight on the rear? Seems like that would put alot of strain on the axles, and wear tires alot quicker.
Old Apr 28, 2004 | 12:49 PM
What did it run you for install?? Did you just get the diff or the Eaton and gears? Wish I could find a place to install them here at a reasonabble price.
Old Apr 28, 2004 | 09:46 PM
KeukaZ71's Avatar
i love my Eaton Posi. great mod
at first i was going to have someone put it in for me, but i had a hard time finding somewhere cheap. so i bought the tools i needed and tried putting it in myself. i never seen the inside of a differential until the day i put my eaton in. if i can do it, anyone can. now changing gears is a bit more difficult since you have to change the pinion gear.
Old Apr 28, 2004 | 10:20 PM
I may give the Eaton a whirl!!! Who has or hasnt done the install on their own. I know it cant be too hard, just really time consuming. anybody know where an install guide is that I can look at? Any pointers on shimming the pinion and carrier?
Old Apr 30, 2004 | 07:19 PM
KeukaZ71's Avatar
check with "Agreif". he made a good website for installing posi. he did not so the gear swap so he didn't include how to change the pinion, just the carrier with the stock gears.
i did only the posi, not a gear change. but for the carrier shims, i just threw back in the stock shims. i didn't even need the adjustable shim kit i bought. i guess 7 out of 8 trucks can reuse the same shims. some you will need the kit. i got lucky i guess
