Difference in these cams?
Old Feb 3, 2004 | 11:52 AM
JayStew's Avatar
Default Difference in these cams?
212-218/.522 .529 LSA 114 Dur .050
216-220/.525 .532 LSA 114 Dur .050
I have seen both recommended. They both cost the same. Is there any noticable difference between the two? More bottom end.....or less, better mid-range, more top end?
Thanks, Jay
Old Feb 3, 2004 | 11:57 AM
Flyer's Avatar
The second one is gonna have a little more top end than the first one just because of the more duration. The first one would probably be a better blower cam if you were gonna run a lot of boost, but both would be better than stock. I would kinda like to konw how each of them idle though.
Old Feb 3, 2004 | 12:03 PM
BigTex's Avatar
The second will lope more, have a little rougher idle, and not have quite as much power down really low, but it should make a higher peak and extend rpms out a little more.
Old Feb 3, 2004 | 01:30 PM
JayStew's Avatar
So does the 216-220 lose torque compared to stock or just not gain as much as the 212-218. I do tow some and I'm not gonna be redlining it (too much). I just want a cam for solid gains all-around, that will compliment other mods later on. Opinions wanted.
Thanks, Jay
Old Feb 3, 2004 | 01:38 PM
BigTex's Avatar
Do a search for the 216/220 cam here. Red2k installed it last year in his 5.3 and had issues getting it to idle. I'm pretty sure he lost some low end with it.
Everything else being equal, the more duration you add, the higher the powerband moves, at the expense of low end.
Old Feb 3, 2004 | 03:47 PM
JayStew's Avatar
Thanks Big Tex, I think I'll stick with the 212-218.
2500ZL1
Jan 25, 2016 06:30 AM
JFortner5
Aug 12, 2015 08:46 PM
Denali08
Aug 9, 2015 04:34 PM
tim wellington
Aug 5, 2015 08:42 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
