Diff. between SS 6.0 and other 6.0?
Old Sep 27, 2004 | 09:32 PM
CHAGO's Avatar
Originally Posted by 03ChevSilveradoSS
I Own A 2003 Chevrolet SIlverado SS With The LQ9 GenIII 6.0L V8 Engine And Thers Alot Of Mods That You Can Do With It. Besides With Just 345Hp Thats Pretty Impressive In A Extended CAb Truck, I Mean I Can Hold Off Ford Lightnings Until Around 73-76Mph. So Id Say That LQ9 Engine To Modify. . .Worse Gas Milage bc Of The Higher Compresstion, But We Cant Spend all Our Time Trying To Save The World. And YES Thers A MAJOr Difference Between The 6.0L 300Hp, And The 6.0L With 345Hp, And YOu Knoe Exactly What That Is Bc I Own A 345Hp 6L And A 300Hp 6.0L And Thers A MAJOR DIFFERENCE And That Catagory Would Be Plain And Simple Ol. . .. . . . . . .GRUNT!!!!
Well, I've raced a 6.0L 345Hp SS silverado in my 6.0L 325hp Denali truck stock vs stock and have help my own nicely. So I guess mine has "grunt" also
Old Sep 27, 2004 | 09:52 PM
03ChevSilveradoSS's Avatar
Innali, Im Not Dissing Your 325Hp 6.0L At All, Ive Driven All Three Versions Of The 6.0L's And Im Impressed By All Of them. But Out Of all Of them Ive Driven The LQ9 Was One Of The Most Impressive (Dont Get Me Wrong. . Im For Any And Every New GENIII And GENIV Gm 6.0L). I Know There STrong Engines.
Old Sep 27, 2004 | 10:29 PM
IMD's Avatar
IMD
Banned
nitrous loves compression. you dont need to lower your compression to run nitrous, there is alot of misinformation on this board about that. if you are going to run a big shot of spray at the track, you should be using race fuel anyway.
Old Sep 27, 2004 | 11:00 PM
CHAGO's Avatar
I know, I was just picking on you
Old Sep 28, 2004 | 12:25 AM
James B.'s Avatar
Originally Posted by IMD
nitrous loves compression. you dont need to lower your compression to run nitrous, there is alot of misinformation on this board about that....
Do your homework before casting out such generalizations. Thanks.
Old Oct 22, 2004 | 11:29 PM
jarediocamaro's Avatar
What about cylinder heads? All aluminum heads are the same casting numbers on 6.0s, LQ4 and LQ9?
All 2000 LQ4s are iron? or no? I am looking at a 2000 LQ4, the man said they were aluminum heads, if they are aluminum are they the good ones? If there is any dif at all.
I need this info quick! THANKS!
Old Oct 23, 2004 | 08:52 AM
one03sierra's Avatar
Formerly one92rs
Talking
anything that expands does not like closed area's.
Old Oct 23, 2004 | 03:59 PM
BigBlockChev572's Avatar
Higher Compressoin ratio gives better gas mileage!
Philip S.
Old Oct 23, 2004 | 04:45 PM
Originally Posted by speedy02
The only difference is the LQ9 6.0 out of the ss has flat top pistons and a higher compression ratio 10.4:1 I thank.The LQ4 6.0 out of the 3/4 ton has dished pistons and a 9.4:1 CR.
LQ9 has a 10:1 CP. LQ4 has 9.4:1
Philip S.
Old Oct 23, 2004 | 04:52 PM
CHAGO's Avatar
yes, that is why I dont wear tight jeans, just in case my crotch area expands.........
