did i go too big
Old Apr 21, 2008 | 12:21 PM
zapata41's Avatar
Default did i go too big
ok so my specs are in sig, but here they are again. truck is 5.3l with comp x259hr cam, i have pacesetter LT with 3" ypipe to 3" single flowmaster 40, then dumps out before rear axle. did i go too big on the exhaust sizing. my bottom end isnt what is used to be with shorty headers but havent fully tuned for LT's yet
Thanks
Tim
Old Apr 21, 2008 | 01:54 PM
RandomHero's Avatar
how about actually posting the specs on your cam instead of that number which doesn't show up on comp's website. Also, are you running an aftermarket torque converter? You can't just throw in a big cam and expect your low end to stay the same.
EDIT-Ok I found it. It's actually the xr259hr which is a 206/212 duration cam. That is a very small camshaft and you should have experienced hardly any low end loss with it(you may have even gained). When was the last time you had it tuned? Was it tuned for the cam?
Old Apr 21, 2008 | 02:14 PM
95 bright teal's Avatar
Its the long tubes and nearly no backpresser from your exaust. i would recommend a good tune and you should be good to go.
the 5.3 do alright at 220/220 after that you will run into problems so your cam should be just fine
Old Apr 21, 2008 | 03:29 PM
D_reks{5.3}'s Avatar
ya after the tune you should be fine.
Old Apr 21, 2008 | 04:26 PM
nightrunner's Avatar
Mr. Obvious
since you are asking abut your exhaust being too big and not the cam, no your exhaust is not too big. just needs tuned and it will be better
Old Apr 21, 2008 | 07:49 PM
zapata41's Avatar
thanks for all the input, exactly what i wanter to hear. yeah i need to find another place to tune it as my last place just ripped me off and did nothing.
again thanks and sorry i didnt put the cam specs up there.
Old Apr 21, 2008 | 08:17 PM
bluecajun5.3's Avatar
11 Second Truck Club
its in the tune.
not the cam, lt's, or exhaust.
Old Apr 21, 2008 | 08:52 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
lmfao
+1 on Tuning getting your power back.
Old Apr 21, 2008 | 09:13 PM
BLACK-SS's Avatar
definately have it tuned the long tubes flow better and are designed for high rpm applications you will lose some low end with them
Old Apr 21, 2008 | 09:28 PM
InchUp's Avatar
Only if the pipe I.D. is too large. Match the pipe size with the application and there should only be gain across the entire rev range.
03sierraslt
14
Oct 9, 2015 05:53 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
The_W
Oct 1, 2015 02:35 PM
