Detonation or No???
Old May 20, 2006 | 08:16 AM
SmOkA2k3's Avatar
Default Detonation or No???
Heres the problem the truck drives perfectly normal under light load but if i floor it or am going up a hill or anything putting it underload i get a weird sound from under the hood i was told detonation sounds like gravel in a coffee can and thats what id describe this sound as and to make things worst when i floor it it makes that sound bad and wont down shift or even gain speed just revs and sounds trashy and the Service light will flash for a few which i was told means "Catalytic Damaging Misfire" but today it threw a "P0101 Mass or Volume Air Flow Circ Range/Performance" i used my handheld to scan for DTCs anyone know what this is or any clues? any help would be greatly appreciated as for condition of the truck it curently has the factory tune in it has for over a year and uses 87 octane as soon as im empty ima fill up with 91 to see if it is detonating from Q-Trip 87 im just at a loss as to what can be wrong
Old May 20, 2006 | 06:13 PM
TarheelZ's Avatar
Dang...punctuate, man, punctuate!
Old May 20, 2006 | 07:14 PM
RoninsDenali's Avatar
Do you use a Oil'ed airfilter. ?
As the P0101 seems to suggest a MAF sensor related problem. If you do use a oiled type filter, clean that MAF sensor gently using residue free electronic cleaner.
Old May 20, 2006 | 07:16 PM
SmOkA2k3's Avatar
Yes i use AEM brute force the oldones that are oil based not there new ones i use a K@N recharge kit thank you for that i will try that and as for puncuation im sorry that im an uneducated oklahoman dont hate me for it
Old May 21, 2006 | 03:53 PM
TarheelZ's Avatar
Originally Posted by SmOkA2k3
...im sorry that im an uneducated oklahoman dont hate me for it
Sorry, not trying to be a dick...it's just that a '.' at the end of each statement makes it easier to decipher.
Old May 21, 2006 | 04:49 PM
SmOkA2k3's Avatar
Not a problem i just type these fast and dont edit
I cleanedmy MAF today with non risidual electric cleaner and its still no diffrence could my MAF be bad? <-- look a (?) but anyways this has me really worried i sounds like very bad pinging or a backfire though the intake i dunno i think tomaro ima see if i can find a used maf at a junk yard and take it for a test drive see if it fixes it any other suggestions would be appreciated if not il let this thread die seems to be an issolated problem with me since very lilfeed back fromsuch a large forum
Old May 21, 2006 | 05:08 PM
Might be a good idea to pull the plugs and see if any one of them are fouled. MAF sensor could have been a bit off, and over time fouled a plug. Keep us updated!
Stroker 1500
Feb 9, 2005 08:44 AM
TireFryerSS
Jun 16, 2004 10:39 PM
greentahoe
27
Jun 8, 2004 08:09 PM
ranwalk
May 24, 2003 07:47 AM
tbyrne
Aug 16, 2002 09:02 AM
