Destroked 6.0L? Need Info
Old Feb 12, 2004 | 09:39 PM
BigJ's Avatar
Default Destroked 6.0L? Need Info
What are your thoughts on this set up? 6.0L block bored 30 over, 4.8L crank, forged internals (plus whatever can be done to the 4.8 crank) cam (not sure on specs, but thinking of something that makes good power up to 7000rpms), 6.0L worked heads, a nice big turbo, a little juice, hamm headers, pulleys, fans, custom tune, 4.10 gears, 3400 stall, and a well built 4l60E.
Basically, it makes a 6.0L a 5.4L (333ci 5.46L) but you can spin it up pretty high. For a turbo the higher the rpms, the higher the boost. That's how I understand it anyway. I'm pretty sure it would move out of the hole pretty good too.
Please comment, I'm curious if this would be worth it, or just better to go all out with a 408.
Old Feb 12, 2004 | 09:50 PM
Why?Unless you are trying to decrease engine displacement to be legal for a racing class there's no reason to destroke the motor.I think you would be missguided to think you'll find a performance advantage by revving a destroked motor higher to make the same horsepower at higher revs at the expense of low and midrange power.
Old Feb 12, 2004 | 10:01 PM
GREGGO's Avatar
Well, explaining why you went with a 408 sure would be simpler. I am curious to know if it would be worth it to run that high of RPM's with the weight of a truck.
Old Feb 12, 2004 | 10:06 PM
BigJ's Avatar
I know there is not a performance advantage compared to a 408, but saving $2500 on a Lunati 4340 4" crank, makes a big difference. Trying to save for the above mentioned mods is gonna take long enough, so if I can make comparable power and save a considerable amount of money on a crank it might be advantagious. Thanks for the input guys!!
Old Feb 12, 2004 | 10:12 PM
Deckhand's Avatar
i think your boost level would be really big, so i think a turbo would be cool on a high reving 6.0.
Old Feb 12, 2004 | 10:15 PM
parish8's Avatar
single digit dreamer
more cubes have to be better, do you need a 6.0 stock crank?
Old Feb 12, 2004 | 10:25 PM
Deckhand's Avatar
also ap-engineering has a 408 stroker for 3600 bucks or so..
may want to look into that?
Old Feb 12, 2004 | 10:54 PM
BigJ's Avatar
I've got my stock crank, so I don't really need one, but how much you want for it? the more I can keep on my 5.3L the more I can sell it for, so I might be interested. Do you think the stock 4.8 or 5.3/6.0 crank will hold up with this setup? Also, I know there is no replacement for displacement, but running higher rpms means more boost, so do you think it's possible to make similar power compared to a 6.0 or 408? Running more boost means more stress on the internals, so would there be anything I could do to a 4.8 crank to make it stronger?
Sorry for all the questions, I'm just ready to decide on which way I'm going with this project so I can get started.
Old Feb 13, 2004 | 12:32 AM
parish8's Avatar
i really dont know what you just said, lots of conflicting info there.
the truth is you can make as much power with any displacement as you want, just turn up the boost. It will be much easier to make the power with a 409 vs a 5.4 or 4.8 or whatever.
i would rather run 8psi on a 409 and get 600hp then run 15 psi on a 4.8, they both might be the same hp but the 409 will run on pump gas.
any of these stock cranks will be strong enuff, there are guys over 700rwhp with stock cranks on this site.
from what i have seen the 5.3 you have there is worth about nothing, the heads might get you a few hundred but the rest of it is prety much worth nothing. use any parts off of it you can, can't remember if the stroke is the same for a 5.3 and a 6.0 though.
what is your budget? and what are your hp goals? stock 6.0 with just rod bolts and forged slugs may be all you need. a built 409 with a turbo set up will be capable of ALOT of HP, are you shooting for 700+hp cause that is what that set up would be able to do, that means big fuel system, pain to tune, drive line is done the list is long.
Old Feb 13, 2004 | 01:08 PM
XLR8NSS's Avatar
Adkoonerstrator
Bore the 6.0L block .030 over and go with the stock crank, forged rods, and forged pistons. Build it for boost and adjust the wastegate accordingly.
After seeing how much power some guys are making on smaller BUILT 348's at reasonable boost levels I think a forged 370ci motor with a big turbo could be WICKED.
Of course a bigger displacement motor will make more power on pump gas but, unless you're truely insane like parish8 then I don't think the extra displacement is worth the extra cash with FI.
More rpms on a turbo setup don't mean more boost. The wastegate controls boost levels and MOST setups on mid size V8's spool BY 3500rpm from what I've seen. A bigger turbo may take a little longer to spool but, that'll give your tires a slim chance of hooking.
