Descreened MAF?
Old Apr 27, 2003 | 12:12 PM
INDIGO 5.3's Avatar
Default Descreened MAF?
I have a descreened MAF, I have mixed opinions about the power. I remember when I first desreened it I felt quicker throttle response. I don't know if I lost power ,but if I did I will buy a new one. What is everyone's opinion on this?
Old Apr 27, 2003 | 01:23 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Default Re: Descreened MAF?
All the stuff on the engine that alot of people mod has a purpose.
The MAF sensor has a screen to reduce air turbulence because the air needs to be correctly metered by the wires of the sensor. As airflow through the intake changes(depending on where the RPMs are obviously), so does the places where air swirls around at different speeds in the tube. If the intake tube was straight it wouldn't be needed, look at the Camaro SS for example. The screen on the MAF keeps these values from fluctuating. If fluctuation happens the computer will compensate for fuel, but at the expense of constant adjustment to the "learned or long-term fuel trim" and "short-term", giving you poor idle quality and reduced fuel economy. Yes, the screen hinders airflow somewhat, but I would think removing it affects the health of your engine. I left the screen on my truck on.
I have heard that a de-screened or GMS MAF is bad with superchargers. I don't know much about forced induction so I couldn't help you in that dept. regarding MAF...
Of course, this info is just bits and pieces of info I put together from reading many people's experiences. Someone please confirm?
Old Apr 27, 2003 | 02:50 PM
MacADaYear's Avatar
You are right Chingon but there is still a point to do the descreen...
From what basics I understand the computer thinks its flowing more are thus riching the fuel mixture this givn u alittle more umph...
Its not like that little screen is gonna let that much more air in...
Old Apr 27, 2003 | 06:56 PM
GF7PE's Avatar
when I descreened my maf I gained 2* of timing at wot. Granted I am really low on the timing to begin with
Old Apr 28, 2003 | 06:03 PM
I've heard varying results from people ranging from, "I felt a little more power" to "Now I have to buy a new MAF." Do you honestly think these guys who supposedly "gained" HP would have been able to tell a difference if someone secretly descreened their MAF without their knowing? Or is it just psychological?
There may be a "point" to doing the descreen, but I don't believe that the minute amount of HP that you MIGHT gain, not to mention the risk of harming your engine, justifies descreening the MAF. This applies especially to stock engines. You can only free up more HP if its there in the first place. I would do it if I had LS1Edit or soemthing to be able to play with the tuning.
Of course, you can do whatever you want to your truck.
Just my $0.02
Old Apr 28, 2003 | 09:31 PM
KeukaZ71's Avatar
well those Italian MAF are descreened.
Old Apr 28, 2003 | 10:41 PM
CashDudeHomie's Avatar
If you're really careful, you can pop the screen out with little to no damage, and if you don't like it, just pop it back in. I do not plan on putting mine back in though. Smoke ur 5.0 if you're reading this, the MAF would make a good dyno experiment.
Old Apr 28, 2003 | 10:58 PM
GoldenVelvet's Avatar
Smoke ur 5.0 did gain power on the dyno if I remember. I have E-fans and my air-intake is a very straight line and I feel like a beter man for having done the mod
Old Apr 29, 2003 | 12:39 AM
Yeah me too. I have a PVC pipe intake and a cone filter, so the air flow should be exactly the same all thru the pipe, unlike some of the premade kits which have bends or don't use a cone filter. (I hope that made sense.
lucas287
31
Jan 12, 2021 06:18 AM
legerwn
56
Nov 15, 2015 10:21 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
ZxHybrid
Sep 18, 2015 04:44 PM
