Denso Iridium plugs
Old Aug 1, 2002 | 09:10 PM
Default Denso Iridium plugs
any opinions? They seem to be the thing for the Lightning. They claim there pretty good
Old Aug 1, 2002 | 09:19 PM
GMC SKI's Avatar
Default Re: Denso Iridium plugs
Do they even make a plug for our trucks ?
I been hearing some negative things about the quality of the NGK plugs maybe just a bad batch made it out to the market?
Old Aug 1, 2002 | 10:27 PM
i dont know. i would think they would. maybe not.
Old Aug 1, 2002 | 11:31 PM
Puffnstuff's Avatar
http://www.densoiridium.com/ and you can look up the part number for your application. For my 99 5.3 it's IT16 gapped at .050 and I've thought very hard about buying some but I want to know for sure if that u-groove in the ground electrode really helps.
Old Aug 2, 2002 | 11:31 AM
AKZ71's Avatar
They look cool but $11.99 per plug seems a bit steep. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Aug 3, 2002 | 04:00 PM
LIGHTNINROD's Avatar
I have a set of IT24s waiting to be installed but I keep putting off the 4 and 1/2 hour job. I need the colder 24s because of the 5lb pulley. I'm running NGK BR7EFs right now--they took me the 4 1nd 1/2 hours to change.
They are expensive but they do not misfire. Probably not necessary uless you're running a s/c/turbo with high boost levels. My OEM plugs were fine with a 3lb pulley and got me into the high 12s.
Dan
Old Aug 3, 2002 | 04:10 PM
GREGGO's Avatar
4 1/2 hours <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> I feel for you.
Greg
Old Aug 3, 2002 | 09:53 PM
parish8's Avatar
single digit dreamer
i can change the plugs in my blown chevy in less than 30minutes, 15 if it is cool.
Old Aug 3, 2002 | 10:13 PM
dutch 99 chevy's Avatar
explain why it takes 4.5hrs. i could chang the plugs in my turck in 25-30min. no prob.
Old Aug 3, 2002 | 10:30 PM
CashDudeHomie's Avatar
Because he drives a lightning. I read in a magazine it is easier if you pull off the wheels and remove the fenderwells.
