Decided to beef up my LS1 (cam Question)
Old Jun 16, 2005 | 01:58 AM
Diablo666's Avatar
Originally Posted by 02sierraz71_5.3
what size stall are you using?
is it an everyday?
tr224 is small for a stroker motor go with the trex id be talking to the fbody guys there are alot of strokers over in thier section
yeah its my daily driver, i don't have a stall yet i want to ge the 3500 or 4000 stall converter.
Old Jun 16, 2005 | 02:03 AM
Diablo666's Avatar
i don't think want to go with the high compression set up anymore 'cause i want to be able to use pump gas.
Old Jun 16, 2005 | 02:12 AM
TheChronic's Avatar
yeah, you want about 8.5:1 compression for a good stout FI setup. If you are going to have everything apart, get some forged reverse dome pistons and 6.0 heads. Talk to the manufacturer for the pistons and get what it takes to make 8.5 comp. I can tell you that much, I'm still looking for a cam for my similar setup...
Old Jun 16, 2005 | 08:03 AM
02sierraz71_5.3's Avatar
Originally Posted by TigerFan187
Yeah Im running stock LS1 bottom end and its making some real good power(not dynoed). Obviously the cam is a bit mild for a LS1 but I literally bought the cam two weeks before I killed the 4.8 and since Im running a stock TC I used it for the LS1. Since Im running the 4.8 heads the CR is pretty high and since the temps have been 85+ I was getting audible detonation so I started using a 75%-93 octane/25%-100 octane AV fuel and the audible is gone but Im still getting 3 degrees detonation at one spot but before it turned hot 93 was perfect! I think the e-fans along with the LS1 intake will take care of it but Im still gonna adjust the tune for the summer. Once I get a bigger cam I wont have to worry about it. I havent dynoed it yet becuase Im not at a point were Im worried about it but will after the new mods. I dont have any track times either becuase of traction issues! **whisper** I still have a open diff! I can roast 20's from a dead stop for a 1/4 mile or so! If I were to safely guess I would say I should run mid 12's on spray mid 13 on motor on 16's!
I took .050 off my 5.3 heads and im runnin into small knock problems nothing that cant be tuned though. let us know when you get some numbers are the heads stock or p/p. I bet she pounds the ground with all that compression
The_W
Oct 28, 2015 09:00 PM
Staggered 02
Aug 11, 2015 07:54 AM
dantheman1540
Jul 29, 2015 04:45 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Black-Syde
Jul 6, 2015 02:12 PM
