DBW Throttle With FAST90 Intake
Old Jan 30, 2009 | 07:20 AM
Denali08's Avatar
Default DBW Throttle With FAST90 Intake
What size is stock GM Truck DBW TB, 78mm? Does it fit FAST90 intake? What's the other option to run FAST intake in DBW GM Truck 03+?
Old Jan 30, 2009 | 08:32 AM
sonoma43's Avatar
IMO save the money dont buy the intake...it wont help much the gains wont justify the cost
Old Jan 30, 2009 | 09:26 AM
ZR1 DREAMING's Avatar
You can run an LS2 or LS7 DBW 90mm TB. Just be sure to get the adapter, Speartech carries one and I think DrX does too.
Old Jan 30, 2009 | 09:29 AM
Denali08's Avatar
I already have heads/cam/ported FAST90/90 on F-body 5.7L engine that will go as whole in the truck. If I put the truck intake/TB it might choke the head/cam plus I will have a ported FAST90/90 doing nothing.
I have F-body accessory drives to use in the truck. To ditch all that because of DBW TB will be a waste.
If the stock DBW TB will fit FAST90 intake, I might end up using it.
Old Jan 30, 2009 | 10:57 AM
sonoma43's Avatar
Ahh I see now...I didnt know you were going to use the tb to compliment whats already done...my bad
Old Jan 30, 2009 | 11:24 AM
andrew383's Avatar
traveling mod
run an ls2 TB.the 3 bolt 78mm truck tb wont work.you need the one with 4 bolt holes
Old Jan 30, 2009 | 06:11 PM
Truckshop's Avatar
+1 on the ls7 with the drx adapter.
Old Jan 31, 2009 | 06:40 AM
Denali08's Avatar
Thanks guys. So, it is either LS2/LS7 DBW TB and Drx adapter or putting stock truck intake/DBW TB.
Is it going to hurt power that much with stock truck intake/TB. It's Vindicator Cam and TFS 215 heads. No plan to rev past 6700. So, is it going to be choked with Truck Intake/TB. I might sell the FAST90/90. Some talk is already going with a possible buyer.
jdb11386
Dec 3, 2015 09:34 PM
Fast86z
Aug 23, 2015 12:35 AM
Slammed96
Jul 27, 2015 07:22 AM
Ammadien
Jul 22, 2015 08:50 PM
Blackrat48
Jul 8, 2015 05:28 PM
