DBW TB as a E-cutout?
Old Jul 2, 2006 | 12:15 PM
tdrumm's Avatar
Default DBW TB as a E-cutout?
As I was looking at a picture of a electric cutout, I realized that it looks an awful lot like the spare DBW TB I have sitting on my bench. A 78 mm TB is slightly bigger than 3", so size wise it would be perfect. I'm sure it's not a standard three bolt exhaust flange pattern, but It shouldn't be too hard to make an adapter.
Do you think it would survive the exhaust temps? I would be installing it just in front of the muffler.
Does any one know how much voltage a DBW TB wants to see when it is wide open?
Old Jul 2, 2006 | 12:34 PM
TravisH's Avatar
thats a pretty good Idea Im not sure how it would work though, I bet the wiring would be a pain, but you may be able to get it like the new Z06's where it would open up at WOT.
Old Jul 2, 2006 | 12:45 PM
BlownChevy's Avatar
blownerator
25 Year Member
I can only imagine the plastic parts of it melting over time and causing you issues down the road.
Old Jul 2, 2006 | 12:50 PM
03sierraslt's Avatar
Old Jul 2, 2006 | 12:57 PM
tdrumm's Avatar
Yeah, that is what I was afraid of.
Old Jul 2, 2006 | 02:08 PM
bluecajun5.3's Avatar
11 Second Truck Club
that's a very good idea. it's just the wireing part and having it last would be the problem. (with the heat and all). i'm sure you'll figure out something.
Old Jul 2, 2006 | 07:49 PM
I dont think the TB was ment to do that. E Cutout motors are made for that enviorment.
Old Jul 2, 2006 | 11:03 PM
budhayes3's Avatar
PT's Slowest Truck
Maybe you could make a heat shield or thermo covering for the throttle actuator/motor. The other plastic items will be removed and plugged (tps and whatever else is there) and wiring should be a piece of cake. Just get a schematic and find which pins are used to move the throttle blade, and wire a switch into them. I think it's a cool idea.
Old Jul 3, 2006 | 12:01 AM
FarmerBeau's Avatar
Sexy Party Mod
even if you welded the holes shut i still think it would leak bad out of the sides. You would have to find a way to seal the perimeter....
Old Jul 3, 2006 | 06:01 AM
tdrumm's Avatar
What holes are you talking about? I would have to make a gasket, and I would use the three bolt holes to bolt it to the cut out. There aren't any other holes that need to be addressed.
