DBW Edelbrock 1000cfm 4bbl TB?
Old Oct 24, 2007 | 12:35 PM
ZR1 DREAMING's Avatar
Originally Posted by silver-mod-o
I cant remember who made it... you wont need a 1000cfm TB on a 370 dude... its just not necessary, even with your heads and cam... 90mm will be all you need.
a 90mm TB just about flows 1000cfm. Besides, I want to run a filter element with a cowl hood and a sheetmetal underside and I can't get that with a DBW 90mm TB.
I guess I might just convert to cable. The set-up I've worked on since the first time I had a Vic Jr should be sick.
Old Oct 24, 2007 | 12:37 PM
Originally Posted by SS_bnoon_SS
I'll be making a fiberglass base for mine to smooth the air flow. I've got a bunch of "wing" shape pieces of wood cut out that I will make the mold out of. Quick scetch in paint of what I'm talking about doing...
I can't open the attachment on this computer... but I'd really like to see what you're working on.
Old Oct 24, 2007 | 12:41 PM
SS_bnoon_SS's Avatar
I put them on my website for you. Hopefully you can see them now...
Old Oct 24, 2007 | 12:52 PM
BlackGMC's Avatar
Resident Retard
SS_Bnoon_SS, that is a great idea however if the engine heat transfers to that fiberglass it will cause it to warp and become brittle.
Old Oct 24, 2007 | 01:01 PM
Hummmmm, perhaps you're right. Maybe some high heat poly-carb or polystyrene resin???
Old Oct 24, 2007 | 01:05 PM
BlackGMC's Avatar
Resident Retard
IMO I think modifying a Drop Base Carb air cleaner would be easiest, using something like this
http://store.summitracing.com/partde...5&autoview=sku
Or if you have access to a welder make the adapter out of steel.....
Old Oct 24, 2007 | 01:19 PM
Damn, that's what I was looking for but could never find! AWSOME!!! I already have an old Moroso drop base assembly from years ago to use along with the linked adapter. The drop base does have quite a bit more room under it to fit the high throttle body too. Click => ordered!!!
Old Oct 24, 2007 | 01:24 PM
Thanks, that works!
I looked at that piece too, they have a nice set-up for carbs that I wanted to run with that 4bbl TB also.
thewrx
Oct 6, 2015 10:59 AM
turbo6c3
Oct 5, 2015 06:11 PM
jfuegner
Sep 22, 2015 12:30 PM
xtrooper89
Sep 21, 2015 06:03 AM
cousblake11
Sep 9, 2015 06:52 PM
