damn thing wont start!!!!!!
Old Sep 22, 2006 | 08:26 PM
LesPaul's Avatar
Default damn thing wont start!!!!!!
well i got the 6.0 in and filled up with fluids...... it turns over and right when it feels like its going to start.... it shakes violently and then starts over and does it over and over again..... its dark out now so im going to go in the morning and look for missed grounds..... do you think thats what it is or do you think im f ' ed something up
Old Sep 22, 2006 | 08:34 PM
Derek @ EDO's Avatar
FormerVendor
double check all your plug wires, some may have came loose. check and see if you are getting any fuel, Is the SES light illuminated ?
Sounds like a random misfire problem
Old Sep 22, 2006 | 08:39 PM
LesPaul's Avatar
well let me tell you the whole thing first..... and first of yes the ses light is on when key is forward.... i am getting fuel cuz i did the age old didnt connect the fule lines when i first tried to start it... mmmmm love that smell....... anyway first i tried and it did like discribed before and then died..... so i hooked up some jumpers to it and then it just kept going.....
Old Sep 22, 2006 | 08:59 PM
FormerVendor
it kept running or it kept turning over?
Old Sep 22, 2006 | 09:08 PM
dewmanshu's Avatar
Moderately Differentiated
i am sure i am asking a dumb question, you have a 6.0 pcm or tune in?
Old Sep 22, 2006 | 09:17 PM
LesPaul's Avatar
it kept turning over... you know the usual 3 - 4 turns and then it would shake like it was supposed to sart.... then it just did that in a cycle....
i have the 5.3 tune in it now just for test running resons.... didnt want to do a relearn if i wasnt sure if it was going to start....
SO NOW HERE IS THE DUMB PART!!!!!!! i just ran to the gas station for beer and smokes and on the way home it dawned on me........... I FORGOT TO TIGHTEN HALF OF THE INTAKE BOLTS No brains no headaches i guess
Old Sep 22, 2006 | 09:19 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I don't think the tune/PCM will matter. I ran mine on the 5.3 factory PCM with Hypertech tuning for a few weeks. Mine fired right off. If you are sure you are getting fuel, check for spark. I'm not sure about all of your "details", ie. stock valve train, (timing may be way out), was it a complete motor, did you swap intakes, etc (May have a serious vacum leak) My swap was simple as I had a complete motor, COMPLETE down to the spark plugs and wires. Recheck all of your connections around the coilpacks and such. Pull a plug and see if you are getting spark.
Colby 04's Avatar
Make sure the wire harness' to the coil pack mains aren't crossed.
Make sure you have the left bank coil pack harness to the left bank and not vise versa
It's happened before and caused a similar symptom...it's worth a shot
Old Sep 22, 2006 | 09:21 PM
Colby 04's Avatar
The internet has you spoiled
You turned to PT before actually trying to work the problem
good luck with the startup
trever1t's Avatar
2nd fastest 5.3 ECSB
Dont forget to tighten all the intake bolts
