Damn header bolt
Old Jun 15, 2006 | 02:00 PM
LesPaul's Avatar
Default Damn header bolt
well i put the headers in a couple days ago.... everything went smooth till i noticed that the dirivers side back bolt was broke off in the head..... i had one other bolt that was broken but it came out nicly with a vice grips... but the other one is broke of with no threads showing..... i DO NOT want to take the heads off but i just cant get a drill or anything in thier any ideas?
Old Jun 15, 2006 | 02:09 PM
Whippled 496's Avatar
right angle drill, easy out, yell at it.
Old Jun 15, 2006 | 02:36 PM
Yelo's Avatar
skip the bolt.....I had one broken off and I just skipped it until I did my head swap, as long as you've got good headers and gaskets you shouldn't have a leak
Old Jun 15, 2006 | 02:56 PM
LesPaul's Avatar
i have pacesster headers and used thier gaskets they were nice thick copper ones it leaked bad then tryed the stockers and leaked even worse so
Old Jun 15, 2006 | 03:09 PM
LesPaul's Avatar
just came up with something tell me if you guys think i will work..... what if i take part of a gasket and use a 2 layer gasket just in that one spot?
Old Jun 15, 2006 | 03:31 PM
SSlow 4.8's Avatar
worth a shot, thats a bad angle to get a drill in there i know
im willing to bet there will still be a slight leak
Old Jun 15, 2006 | 03:41 PM
Bowtie70SS's Avatar
Take the inner fender well and the steering shaft out....maybe you can get it then? When you drill it try and get a LH drill bit so as you drill it, it may back out.
Dave
Old Jun 15, 2006 | 03:57 PM
LesPaul's Avatar
how much TQ are you guys tightening to.... i turned them to 20 lbs does that sound right?
Old Jun 15, 2006 | 05:10 PM
LesPaul's Avatar
in case you guys were wondering i tried that gasket thing. and it made it alot quiter but it still had a nasty tick to it...... not sure what im going to do but that tick is going to drive me crazy
Old Jun 15, 2006 | 06:47 PM
99LoweredSierra's Avatar
18lbs is usally what people go to so u should be ok but i wouldn't do more!
