damn codes
12 Second Club
yeah when i put the new engine in i put mid-lengths and took off the cats with a custom y-pipe. then i installed the front 2 02's and unplugged the rears. i know i got to get the rears turned off (witch is the 161 code i think)
Yea, sounds like you either have a bad front bank1 O2 sensor, or the wiring to the sensor is damaged...check and make sure that none of the pins are backed out of the connectors and that none of the wires are broken. If that's OK, then more than likely the O2 sensor is poop.
