D-max intercooler going in tommorow!!!
Old Oct 29, 2004 | 01:18 PM
  #21
Don't forget to re-tune to take full advantage of that monster of an IC.
Old Oct 29, 2004 | 01:20 PM
  #22
F8L Z71's Avatar
Originally Posted by hefdaddy007
all that stuff sits on the outside. the innercooler goes where the radiator is now then the radiator bolt to the innercooler. i'm gonna wait till i get my turbo then put it all together at once. still need 42lb injectors!! any help??
I'll be selling my injectors as soon as I get my 6.0L in. Might be a few months though. If you still need em by then I'll sell.
Old Oct 29, 2004 | 01:35 PM
  #23
Black Blown 02's Avatar
When I swapped my ATI cooler for a bigger unit, my air/fuel ratio went from 11.7/1 to 10.5/1, so a retune is a must.
Old Oct 29, 2004 | 01:38 PM
  #24
GoldenVelvet's Avatar
I don’t get why more people don’t go for the D-max intercooler. Its cheep frigging Huge and a direct fit. I guess it makes too much sense and that’s why we cut and fit other intercoolers.
Old Oct 29, 2004 | 01:44 PM
  #25
F8L Z71's Avatar
I don't see how it is a direct fit at all. I looked into my radiator area and there is no way in hell one would fit into mine without relocating other coolers and stuff. Plus I'd be worried about airflow to my already taxed radiator with these stupid electric fans.
Old Oct 29, 2004 | 02:11 PM
  #26
Chevmann99's Avatar
So would there be any concern with lag in a setup like mine? I am running a 9psi Procharger in a 2500HD with the little ATI cooler under the bumper. I would love to put a D-max cooler in especially if it's basically a bolt in, just for piece of mind and to get my off road capability back with out worrying about trashing the cooler. I bet I could safely run more boost too I'm thinking an 11 PSI pulley would be easily do able with that big ole thing.
Old Oct 29, 2004 | 02:12 PM
  #27
Look at a D-max side by side your truck and you will see it is a direct fit. The D-max does have a higher capacity radiator (as all HD's do).
Old Oct 29, 2004 | 02:19 PM
  #28
F8L Z71's Avatar
Wierd, doesn't look like it to me without relocating at least the oil cooler. Otherwise nothing will fit between it and the radiator. Either way I doubt it's as much work as fabbing in an IC like the one I have.
The main concern is have you seen any results with one yet?
Old Oct 29, 2004 | 02:49 PM
  #29
I logged before and after airflow with my bigger cooler and gained flow throughout the rpm range no lag to fill the increased airspace at all. My 60' also went from 1.91 to 1.80 with the swap.
Old Oct 29, 2004 | 03:16 PM
  #30
OLD BULL's Avatar
Will the intercooler cool the charge down enough sitting behind the radiator? Are the Duramax trucks setup that way? Would it hurt anything to run an intercooler in front of the tranny cooler and power steering cooler? I'm asking so many questions because I'm having a hard time choosing which IC I want to run, and I really don't want to moddify to much in that area.
