Cylinder Head Water Vapor Lines
Old Jun 22, 2010 | 02:23 AM
Mrgoodwrench3's Avatar
Default Cylinder Head Water Vapor Lines
I made some new water vapor lines for my truck. Yes I know the stock set up was fine but this looks Cool !
Old Jun 22, 2010 | 03:02 AM
silverado2000's Avatar
looks good
Old Jun 22, 2010 | 06:30 AM
SweetS10V8's Avatar
Looks good, nothing wrong with taking a good working part and upgrading it, simply to upgrade!
My wife always asks me when I buy new parts "Is the old one broken, or are you just doing this for fun?"
00buckshot's Avatar
I hate to thread-jack, but what would happen if you blocked the ports off like with the plugs that go on the back side??
Old Jun 22, 2010 | 09:32 AM
The ports are there to vent any air pockets out of the heads. They insure the heads are full of coolant around the cylinders.
Old Jun 22, 2010 | 09:45 AM
BlackGMC's Avatar
Resident Retard
I like it, those look great!
Old Jun 22, 2010 | 10:13 AM
Preston129's Avatar
Do you have to seal the ends that thread into the head with teflon tape? and for the fittings that do go into the head, are they just metric to -AN adapters?
I really like this idea and may have to steal it for my truck!
Old Jun 22, 2010 | 10:39 AM
scooter k's Avatar
Those definitely look better then the factory ones.
Old Jun 22, 2010 | 10:47 AM
I got the adapters from Kurt Urban. They fit into the heads just like the factory adapters. I then just used -4 AN fittings from Jegs.
Old Jun 27, 2010 | 08:43 AM
Preston129's Avatar
What did you do on the line that T's off the passenger head and goes to the rad? Did you just add an AN socket to the stock rubber hose? Or replace the whole thing with the same hose you used for the crossover piece?
