cutout ??
Old Jan 14, 2005 | 04:52 PM
Default cutout ??
has anyone put on these cutouts? I would like to do this with the VHO but only want one toggle switch and would liek to put that in the lighter hole. are these hard to wire up? any help would be appreciated.
http://www.quicktimeperformance.com/...ct_detail&p=76
Old Jan 14, 2005 | 05:31 PM
Quick Time's Avatar
Its very easy to wire up. Give us a call on monday and we an help you out.
Old Jan 14, 2005 | 05:43 PM
GREGGO's Avatar
That's exactly what I have. It only has one toggle switch. Just a couple wires to hook up and the rest just plugs in. Very simple to do. Put the switch where ever you want. They give you plenty of wire to work with. I have had mine on for over a year and have opened and closed them hundreds of times. Not one problem. Very happy with them.
Old Jan 14, 2005 | 06:08 PM
can you open them partially or do they automatically open all the way?
Old Jan 14, 2005 | 08:46 PM
04sierra's Avatar
Have you had any problems with them leaking when closed?
Old Jan 14, 2005 | 08:55 PM
GREGGO's Avatar
You can open them partially. The toggle even has a green led when opening and a red when closing.
They don't leak, but they are a metal on metal seal, so they won't be water tight. They won't be any louder than a regular exhaust when closed.
Old Jan 18, 2005 | 08:31 AM
thanks, that's what I wanted to know.
Old Jan 20, 2005 | 09:31 AM
BLACKND's Avatar
Sorry to drag this one back up, but I am now considering the electric cutouts too. I was looking on quick time performance before I knew they were a sponser here. I am going to be doing headers soon too, and would like to do these at the same time. A few questions though. I am running 2.5" dual pipes all the way back right now do I need to get the same size cutouts? Are these like a butt weld type setup or do I need to open the pipe up a little to slip over the cutout? Also, I am running an x-pipe, should I put the cutouts before or after the x?
Old Jan 20, 2005 | 10:41 AM
I plan on doing the same thing, jsut waiting for the B-DAY in Feb. I wouldliek to know the same about getting the same size as your pipe is now or bigger. also where in the exhaust is everyone installing them. I will get an x pipe and take off the cats before they go on.
Old Jan 20, 2005 | 10:55 AM
greentahoe's Avatar
I thought I remembered reading that they should be right after the X or Y pipe. Someone suggesting in place of the cats and it was agreed that said placement would ruin the scavenging effect or something like that
GXPJAY
Feb 13, 2022 08:15 AM
KleanKustoms
Aug 27, 2015 10:16 PM
Zack R
Aug 3, 2015 06:02 PM
Atomic
Jul 11, 2015 03:51 PM
