Custom tuning tow/haul mode
Old Jul 12, 2004 | 10:44 PM
Round Rock TA's Avatar
Default Custom tuning tow/haul mode
Can you custom tune tow/haul mode? When you press the button there is a change in the truck. I know that the shift points change from when it is off but I am not sure if anything else changes. Of course this has to be done through the PCM. Can a custom tuner see this in the PCM and have one set of tunes (or at least shift points and TM) for normal driving and a different set of tunes for when the tow/haul mode is on? Of course tow/haul mode will have to have its name changed to haul/butt mode.
Old Jul 12, 2004 | 10:48 PM
yes, LS1edit allows this - shift ponts and some other transmission modifications only. No motor changes through tow haul though.
Old Jul 13, 2004 | 10:02 AM
marc_w's Avatar
Yup, in HPT, it's called "Performance" mode. You can only modify shift points (which shift vs TPS vs speed), and torque converter clutch lockup points (apply/release vs TPS vs speed)
Old Jul 14, 2004 | 12:18 AM
BigTex's Avatar
Yes, this works great. You can also change the shift firmness and shift speed for the performance mode. Torque management happens in all modes and isn't selectable with a switch.
I have mine set that way now. Normal shifts until I hit the button. Then it holds the gears for more rpms under all throttle levels. That lets me cruise along and wind up the gears without it shifting into a very high gear. Its ready to go full throttle instead of having to down shift.
5.3Okasai
Mar 9, 2022 01:07 PM
Ferocity02
Aug 7, 2015 08:50 PM
Castro45
24
Jul 31, 2015 07:13 PM
Ketis
Jul 23, 2015 12:37 PM
