custom CAI pics?
Hey, those of you that have fabricated some custom CAI stuff, are there pics on a thread anywhere? i was looking today at my stock setup tryin to figure what to do. i don'y like the open top designs, thinking of doing a custom tube and using the factory airbox, possibly with some mods there. do the conical filters really flow any better than the stock airbox? seems all the stock airtube stuff may be the restrictive factor.
Also, anybody that's converted to efans, hvae you changed the radiator hose to something a little more straightfoward? the factory hose curves way around, but seems like that would be unecessary after removing the fan clutch shroud? |
BlackGMC made a really nice CAI, my buddy Zach built a pretty sweet one as well. I'm sure they'll chime in.
Originally Posted by jakebdb56
(Post 3842100)
Originally Posted by lawdog49
(Post 3841951)
Also, anybody that's converted to efans, hvae you changed the radiator hose to something a little more straightfoward? the factory hose curves way around, but seems like that would be unecessary after removing the fan clutch shroud? http://i27.photobucket.com/albums/c1...ck/Lid2-15.jpg Part-1 Part-2 In fiberglass w/ factor airbox bottom 4in tube and elbow http://i27.photobucket.com/albums/c1...GMC/Final2.jpg Part-1 Part-2 I am working on a new design with a fabricated airbox bottom and new lid, with the opening behind the headlight and dual ram air scoops in the tow hook spots.... Sorry i get bored and like to build stuff, besides I gotta try out my new band saw.....:devil: |
You'll need something to support the hose, so you might as well reuse the original piece, get a straight piece of metal, bend a curve in it, drill a hole in the center of the radiator support, secure the piece of metal, and place the hose on it. I hope that made sense.
On my efans I just drilled some holes in the radiator support and used the existing clamps
http://i27.photobucket.com/albums/c1...uck/Efan05.jpg Then I made a bracket that attaches to the intake tube with another clamp http://i27.photobucket.com/albums/c1...ck/Lid2-12.jpg |
Very nice job!! I wish I could weld like that.
About how far off the radiator do your fans sit? |
really nice work blackgmc. lemme know if you wanna sell your current setup when you get the new one made! so, can i get 4" elbows and tubes, or will I also need a reducer/coupler to mate the black flexi hose coming from the MAF? i measured the ID of that hose, and it seems to be 4". don't think it will flex/stretch enough to go over a 4" tube.
any comments on air filters to use in the stock box? |
Originally Posted by CashDudeHomie
(Post 3842159)
(Post 3842277)
Here is my custom intake: UPD Lid with rubber hoses and tubing (unpainted)
http://i76.photobucket.com/albums/j1...g?t=1202228164 http://i76.photobucket.com/albums/j1...g?t=1202228197 http://i76.photobucket.com/albums/j1...g?t=1202228220 |
https://www.performancetrucks.net/fo...d.php?t=389533
here is a thread from a while back with a few pics. |
