Crank Pulley
How does one go about getting a bigger crank pulley? There are a ton SC owners out there that would be all over this. Who makes the 1ft and 2ft (
) pulleys for the L? Is ASP going to mass produce these, because I'm sure they could make a killing if they did.
Damn, that's some serious coin! How much of a boost increase would that give you, that's only a 1/4" increase?!? That can't be worth all that much.
Oh yeah, sorry that was a typo.
So as a Radix owner, do you think that's worth it? It beats putting a smaller pulley on up top, but the price is more than double. I'm sure it would come down a bit if they mass produced them though. Maybe B will chime in with some R & D insight that Magna has done.
Is it possible to boost lets say a 5.3 to +12psi w/o using a crank pulley, and w/o running the risk of a slipping belt (i.e. no roller skate wheel pulleys)???
Originally Posted by whitt1
The bigger crank pulley would reduce belt slipage,but it would increase the speed of the alternator,waterpump and power steering.
Yep....and the increase the amount of wear on all of the above.
