Crank Pulley
Old Apr 4, 2005 | 11:10 AM
moregrip's Avatar
what a rush!
Default Crank Pulley
what is the difference between the truck crank pulleys and the other (i.e. F-body/corvette) crank pulleys?
Old Apr 4, 2005 | 12:12 PM
F-body pulley is smaller and has different location for belt groves.
Old Apr 4, 2005 | 12:17 PM
moregrip's Avatar
what a rush!
I was hoping for specifics, thanks whitt
Old Apr 4, 2005 | 01:18 PM
If you are wanting to speed up your Radix you'll want a larger diameter crank pulley.L-Eater had one custom built by ASP.
Old Apr 4, 2005 | 01:33 PM
moregrip's Avatar
what a rush!
just want the stock size right now. I've heard 7.5 and 7.75.
Old Apr 4, 2005 | 03:56 PM
7.75" is correct for a truck pulley.
Old Apr 4, 2005 | 06:43 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Are the 4.8, 5.3 and 6liter crank pulley's all the same?
Old Apr 4, 2005 | 09:43 PM
Yes all three truck pulleys are exactly the same.
Old Apr 4, 2005 | 09:56 PM
BlownChevy's Avatar
blownerator
25 Year Member
Offset....you will need a new accessory drive like the f-body if you want to use the crank pulley.
Old Apr 4, 2005 | 10:08 PM
Flyer's Avatar
What he said ... offset is the biggest difference.
