Crane adjustable timing chain
Old Aug 17, 2007 | 01:27 AM
Question Crane adjustable timing chain
Will the Crane adjustable timing chain set from VHP work with my cam swap on my LQ9 6.0?
Old Aug 17, 2007 | 08:51 PM
Stoichiometric's Avatar
It will but I would recommend an ls2 timing chain and stock gears. Ask Vinci to see if they have the advance you want already ground into the cam.
Old Aug 18, 2007 | 09:33 AM
tdrumm's Avatar
Yep, I run one in my truck. No clearance problems like others have expereinced with other brands of double roller chains.
Old Aug 18, 2007 | 05:06 PM
Got the Manley Double roller adjustable set from Thunder it was cheaper than the Crane.
Old Sep 8, 2007 | 08:09 PM
mrr23's Avatar
10 Second Club
while the manley is cheaper, in order to make any changes, you have to pull the oil pump and crank gear. with the crane, all you do is loosen the allen bolts, turn the center section where the cam bolts to it and retighten.
here's a pic of it in my 408 motor. i used the LQ9 block. no clearance issues.
Old Sep 9, 2007 | 04:33 PM
Mark Johnson's Avatar
Hallelujia- I'm learning more and more for my dream rebuild. Thanks for the pic........................
Old Sep 9, 2007 | 04:34 PM
mrr23's Avatar
10 Second Club
anytime
5.3Okasai
Mar 9, 2022 01:07 PM
03chevytruck
Nov 7, 2016 04:43 PM
chevyl33
Aug 24, 2015 08:21 AM
Boombastic
Aug 5, 2015 11:38 AM
Ammadien
Jul 22, 2015 08:50 PM
