Cracked block.
Old Feb 13, 2011 | 10:35 AM
  #21
1989k1500's Avatar
I would look for a 5.3 if you dont have money to buy another 6.0. But maybe you will have good luck with the jb weld.
Old Feb 13, 2011 | 11:50 AM
  #22
lsvega-s's Avatar
If you are going to weld it or jb weld it I would drill a small hole at each end of the crack to make sure it won't get bigger. Other than that I would give it a try and keep an eye on your oil level.
Old Feb 13, 2011 | 12:17 PM
  #23
youngbuck's Avatar
My guy is saying he would rather weld it then jb weld it, thought s?
Old Feb 13, 2011 | 12:43 PM
  #24
lsvega-s's Avatar
I would weld it, especially if you have access to a tig.
Old Feb 13, 2011 | 01:27 PM
  #25
la ricky bobby's Avatar
in opinion just go ahead with the welding...and in the mean time if it works out look for a shortblock or if you dont even want to spend that much,,definitely just look for a bare block...
Old Feb 13, 2011 | 01:44 PM
  #26
youngbuck's Avatar
Red face
He is a very good tig welder, would it still need a valley ground into the block or just go over the crack?
Old Feb 13, 2011 | 01:58 PM
  #27
mhotrodscooter's Avatar
Welding in a valley, is almost like welding from the inside out. This makes the weld that much stronger.
Old Feb 13, 2011 | 02:04 PM
  #28
dmelvin's Avatar
I would say if he's as good of a welder as you say, and he's done this before, he'll already know about this.
Old Feb 16, 2011 | 10:34 PM
  #29
youngbuck's Avatar
Talking
block is tig welded up with nickel rod, must waiting to get it back together an start having done fun . Thanks for all the input an advice guys I appreciate it alot .
Old Feb 17, 2011 | 11:34 AM
  #30
Congrats, If I'd known you had access to a tig then I'd said go that way to begin with. Good luck you have nothing to worry about now.
