Cowl hood help with performance
Old Nov 29, 2003 | 12:38 AM
TwoFast's Avatar
Default Cowl hood help with performance
Just wondering since the cowl hood has an opening in the back I would think that it lets heat out of the engine compartment which in turn lowers under hood temps. Have any of you guys with cowl hoods noticed a reduction in underhood temps? Also I noticed on the Goodmark cowl hood that on the opening in the back, there is a section that has holes drilled in it, would it be more functional if I cut that entire section out to release more heat out of the engine compartment?
Old Nov 29, 2003 | 02:50 AM
FILE's Avatar
I personaly don't like Cowl Hoods. They are good for about 90 pounds off your front end so technically they are a weight reduction mod.
Old Nov 29, 2003 | 05:50 AM
L-EATER's Avatar
11 Second Truck Club
I have the Goodmark cowl induction hood. I have not noticed any temp reduction, at least not by monitoring IAT, coolant emp, and trans temp with A-Tap. The only thing you will notice is now you can see light from the headlights through that section with the holes in it. And it is as heavy if not heavier than the stock hood-no 90 lb weight reduction.
Old Nov 29, 2003 | 08:05 AM
one03sierra's Avatar
Formerly one92rs
it will let heat out but not enough for you to notice. and mine was 14 pounds lighter.----goodmark--.
Old Nov 29, 2003 | 12:47 PM
renegade4e's Avatar
14 Second Truck Club
yeah, not much weight or heat loss here either. but what they are good for is collecting pine needles, always getting stuck behind the cowl!
kha4079
Oct 29, 2018 04:38 PM
mikeyjm1
17
Oct 29, 2015 11:04 PM
gaps
Oct 15, 2015 02:53 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
montecarloss
Sep 2, 2015 04:44 PM
