Couple of Edge questions
Old Mar 3, 2004 | 09:11 AM
02RedWS6TA's Avatar
Default Couple of Edge questions
I'm going to be getting a Dmax in september, when my current lease is up. More than likely, unless something better comes out, I'll be putting the Edge Juice box w/attitude monitor on it. Basically the only thing I wondered is can this reprogram the computer for tire changes? I swap tires EVERY winter for the stock tires to plow with. Usually go from 305's back to the stock 245's so there is a pretty big difference in the speedo change.
Well can it? I hope so because I'm pretty set on this. The monitor is awsome and the box itself seems to be the most popular out of them all and has the most support.
Thanks,
Justin.
Oh yeah, how is the gas milage when using these? The only time I use my truck it's either pulling a 5k+lbs trailer with lawn equipment, an open trailer with my ws6 on it, or plowing snow. I currently have an 8.1 and it pretty much blows.
Thanks again.
Old Mar 3, 2004 | 09:16 AM
10 Second Club
I have the attitude monitor on my truck. It is not capable of correcting the speedometer on the truck for tire size changes.
You can, however, select the tire diameter on the screen and the monitor will display the correct speed. It won't fix the speedometer on the truck, though.
I drive in level 5 (125 hp) almost always. I've seen over 19 mpg unloaded and 14-15 pulling the covered snowmobile trailer with the juice.
Old Mar 3, 2004 | 09:31 AM
02RedWS6TA's Avatar
close enough to corrected for me, thanks.
mzoomora
Jan 3, 2016 07:06 AM
Noah Burns
Sep 7, 2015 05:50 PM
USMCvet0311
Aug 1, 2015 07:45 AM
