COT and LTFT questions
Old Sep 18, 2003 | 11:16 PM
BlownAlaskan's Avatar
Default COT and LTFT questions
Hey Guys, I have a couple of questions for you.
1) what could cause my LTFT averages to be different? At idle one bank is -0.76 and the other side is a +2.XX. I just got my new injectors installed last night and I am trying to dial the thing in.
2) which codes should be turned off when COT is disabled?
Thanks if advance.
Ben
Old Sep 19, 2003 | 12:48 AM
Black Blown 02's Avatar
Default Re: COT and LTFT questions
1- Dont know about this one, but mine does the same thing.
2- Turning COT off won't set a code. I just checked the box false for COT, and that did the trick.
Old Sep 19, 2003 | 12:51 AM
Hey, maybe you've posted this before, but what does your "homebrew" intake consist of?
Old Sep 19, 2003 | 08:48 AM
BigKID's Avatar
1- check you exhaust. If you have a major leak it will cause inconsistat readings like that.
2- Only do this if you have removed your cats. If you have removed them and want to turn off you rear O2 there are about 6 codes you have to disable.
JordanH
Dec 25, 2015 08:32 AM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
creekrat
Sep 10, 2015 12:59 AM
