Corsa with LTs and ORY rasp problem solved
Old Oct 10, 2006 | 11:44 AM
Moddoo's Avatar
Thumbs up Corsa with LTs and ORY rasp problem solved
If you don't know yet, this combo will create an incredibly loud metallic rasp/rapping sound. Much worse than the typical header sound. On my truck, it would start at around 2800rpm even with very little throttle.
I decided to get a perforated core/insulation packed muffler to add to the system. This type of muffler is known for reducing higher frequencies.
I settled on a stainless magnaflow 6" round X 14" core, 3" in/out.
It is the largest I could fit in the I-pipe.
When I got the muffler, I immediately replaced the corsa muffler with it, to see how it would work on the rasp.
The truck was LOUD and DEEP, but it dampened the rasp pretty well. I was able to rev to 4000 rpm with little throttle and not get the rasp. When WOT it would rasp, but it was muffled pretty good.
After driving it like this on the freeway, and confirming the worst drone I've ever heard would show up, I had to complete the conversion.
So I cut the I-pipe, and installed the Mag muffler and put everything back together. Fired it up.....
Quiet, mellow, pretty much sounds like stock.
Driving around it is very mellow until you get into it, and it lets you know it's not stock above 3500rpm, but with just a hint of rasp, it sounds similar to how it did before the LTs/ORY went on.
Nearly silent on the freeway. NO DRONE. AND, the "header noise" that seems to come right through the primaries, is reduced quite a bit.
I am very happy with this setup, it's quieter than I expected, but now I can *** around without getting the wrong attention.
I know this idea is not new (add a resonator to help the rasp) But, I wanted to share exactly what I did to help any others with this setup.
Pics and video to come soon.
Old Oct 10, 2006 | 12:04 PM
joehawkz71's Avatar
sounds good....hey hit me up sometime and we can get together....
Old Oct 10, 2006 | 09:16 PM
old motorhead's Avatar
How long over all is your resonator? Part # and cost if it isn't too much trouble. I've found a stainless one made by vibrant performance that's 14" long. Costs $83 + shipping. Not much room under a reg cab short box. Thanks
Old Oct 11, 2006 | 08:06 AM
Moddoo's Avatar
They're on sale at performancepeddler right now for $57.89 shipped.
They also carry a 4 inch diameter with the same length, and some other lengths too.
You could cut off 1.5 inches of the pipe from each end if you need it a little shorter.
Old Oct 11, 2006 | 08:11 AM
Nick™'s Avatar
hmmm... thanks for the info. I have the Corsa Touring system and plan ORY and Pacesetters in the future, so now I'll know what to be prepared for.
Old Oct 11, 2006 | 08:15 AM
Moddoo's Avatar
I'll try to get the pics up soon, It's snowing here today.
Old Nov 22, 2006 | 09:20 AM
Moddoo's Avatar
Finally a little update.
This topic keeps coming up so here are some pics and clips.
My other video files were too big, I'll post some more later.
http://s87.photobucket.com/albums/k1...saclips010.flv
Old Nov 22, 2006 | 12:26 PM
TXsilverado's Avatar
nice setup...you coulda saved alot of money by just going with a dynomax bullet. i did both setups and they are both about the same but the bullet was way cheaper.
Old Nov 22, 2006 | 01:10 PM
Moddoo's Avatar
Thanks man, I actually only paid about $60 for the stainless mag muff.
I really wanted the largest resonator I could get.
I dunno for sure, but I would think this is quieter than a bullet.
Here's a little idle/rev clip. the freeway traffic is almost louder than my truck.
I'll get another clip in a quiet area sometime.
http://s87.photobucket.com/albums/k1...saclips012.flv
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
'02SOMz28
Nov 2, 2015 05:47 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
