Correct way of re-installing rocker arm shafts???
Old Apr 4, 2007 | 05:53 PM
Default Correct way of re-installing rocker arm shafts???
Like the title says fellas. It's been awhile since I have had any spare time to play with the truck (in my sig.). So I have forgot a few things. The short block is done, The cam is in, double roller on,oil pump on, I installed the heads and ARP bolts (still not confident about that) I think I'm going to go back and re-torque the heads.
Okay once I get the heads re- installed how do I install the rocker arm shaft. Do I just torque it down to (I think) 22 ft lb ? I am re-using the old lifters so would it make a difference if they are dry or filled with oil? Thanks for any help.
Danny
Old Apr 4, 2007 | 06:39 PM
thunder550's Avatar
High on diesel fumes
No difference, 22 ft-lbs it is.
Old Apr 4, 2007 | 08:03 PM
Cool thanks....
Old Apr 5, 2007 | 09:16 AM
I forgot to ask about adjusting each individual rocker arm . Do those have torque specs too? And do I have to spin the engine to adjust them or in any special sequence?
Thanks again
Danny
Old Apr 5, 2007 | 09:21 AM
bluecajun5.3's Avatar
11 Second Truck Club
they are torqued to 22 ft. lbs.
use some red locktite on the threads also.
torque them all down, rotate the engine 180* and retorque againg to make sure you haven't missed any.
Old Apr 5, 2007 | 09:58 AM
alright I'll re-install the heads and install the rocker arms today . Why red loctite do they come loose?
SlvrSierra4.8
Oct 1, 2015 09:39 PM
vipergtrdj
Sep 16, 2015 07:06 PM
chvy=power
Sep 8, 2015 11:06 AM
xerox17
Sep 5, 2015 01:23 PM
