Cooling system question
Old Nov 25, 2006 | 11:06 AM
14 Second Truck Club
Default Cooling system question
When swapping a motor, after the motor is put back in, how do you fill the cooling system back up?
Old Nov 25, 2006 | 11:26 AM
99Silver6.0's Avatar
Through the overflow tank.
Old Nov 25, 2006 | 11:29 AM
You can fill it through the radiator hoses. I would at least make sure you fill the radiator all the way up through the upper hose.
Fill the Coolant bottle and leave the cap off prior to starting engine. The coolant will then slowly vent all air through the coolant bottle fill and start to go down. Place fluid in as it goes down.
Jim
Old Nov 25, 2006 | 11:42 AM
Where is that?
Old Nov 25, 2006 | 11:43 AM
Jim
Just disconnect the hoses and fill it up through each one? Thanks for the info!
Old Nov 25, 2006 | 11:44 AM
sroach20's Avatar
Where is that?
the big clear tank next to the airbox.
Old Nov 25, 2006 | 11:51 AM
Derek @ EDO's Avatar
FormerVendor
i just poured in the coolant in the clear jug.
Oh, Duh!
Old Nov 25, 2006 | 01:41 PM
Make sure your using a 50/50 mixture! Don't use water or shall I say tap water. You need to use distilled water or make it easy and buy the Prestone 50/50 pre-mixed approved Dexcool.
Jim
USMCvet0311
Aug 1, 2015 07:45 AM
dantheman1540
Jul 29, 2015 04:45 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
FlowmasterMufflers
Jul 9, 2015 12:00 PM
