Cooling problems?!
Old Jan 11, 2009 | 02:27 PM
fastnblu's Avatar
Unhappy Cooling problems?!
My 04 recently is takin longer to get to operating temp ( according to temp gauge). So therefore, the windows don't defrost as quick. That's a problem. It's 31* today, & headed in the teens this week.
I had the truck running while I did the snow today. For ~45 min, it still isn't blowin hot, yet the temp gauge is ~200*.
Within 10 minutes of shuttin down truck, I was able to touch my the upper & lower rad hoses. To my surprise, neither was hot. I thought 1 or the other, would be. I smell coolant ( could've been from excessive idling).
The overflow is low. If there should be 3" to get the overflow to the full mark ( or halfway) in overflow tank, I figure it's 2" of coolant gone.
When this 1st started, ~1wk ago, I thought great, thermostat.
I'm thinkin look inside rad. & top off. And hope that's it. More than likely, a new T-stat is needed too.
So my questions are this:
When I add coolant, I just add to the radiator, correct?
I know on the Gen2 LT1 u had to fill thru the overflow due to the pressurization of the cool. system/ reverse flow cool.
I can use the old green antifreeze or the new ****, & add to the factory red, correct?
Old Jan 11, 2009 | 03:58 PM
Fireman31's Avatar
There has to be a reason for the coolant loss....it may be time to pressure check the system and have it flushed too. Add fresh coolant to the radiator if your vehicle is equipped with a radiator cap, if not add it to the overflow. A low coolant level and/or a bad thermostat can cause heater problems.
You will want to use ORANGE DexCool approved antifreeze/coolant. you cannot mix the standard green crap with it......and red antifreeze is Toyota coolant......
Old Jan 11, 2009 | 04:06 PM
fastnblu's Avatar
Agreed, it's going somewhere. Ya, I haven't pressure checked it yet. Here I thought the 2 coolants could be mixed. By red, I meant DexCool.
Old Jan 11, 2009 | 09:00 PM
fastnblu's Avatar
Well, it was 2 qts. low. Now I know why I don't ever member seeing a rad. cap under the hood. There isn't one.
Old Jan 13, 2009 | 03:45 AM
CashDudeHomie's Avatar
The green Prestone has been compatible for the past year or two. Just check the label.
dsbodley
Nov 14, 2015 09:46 PM
Lthompson
Oct 2, 2015 12:45 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
carid
Oct 1, 2015 09:22 AM
Wrecker 426
Sep 30, 2015 09:39 PM
