Cooling problems?!
My 04 recently is takin longer to get to operating temp ( according to temp gauge). So therefore, the windows don't defrost as quick. That's a problem. It's 31* today, & headed in the teens this week.
I had the truck running while I did the snow today. For ~45 min, it still isn't blowin hot, yet the temp gauge is ~200*. Within 10 minutes of shuttin down truck, I was able to touch my the upper & lower rad hoses. To my surprise, neither was hot. I thought 1 or the other, would be. I smell coolant ( could've been from excessive idling).:eyes: The overflow is low. If there should be 3" to get the overflow to the full mark ( or halfway) in overflow tank, I figure it's 2" of coolant gone.:ripped: When this 1st started, ~1wk ago, I thought great, thermostat.:bang: I'm thinkin look inside rad. & top off. And hope that's it. More than likely, a new T-stat is needed too. So my questions are this: When I add coolant, I just add to the radiator, correct? I know on the Gen2 LT1 u had to fill thru the overflow due to the pressurization of the cool. system/ reverse flow cool. I can use the old green antifreeze or the new shit, & add to the factory red, correct? |
There has to be a reason for the coolant loss....it may be time to pressure check the system and have it flushed too. Add fresh coolant to the radiator if your vehicle is equipped with a radiator cap, if not add it to the overflow. A low coolant level and/or a bad thermostat can cause heater problems.
You will want to use ORANGE DexCool approved antifreeze/coolant. you cannot mix the standard green crap with it......and red antifreeze is Toyota coolant...... |
Originally Posted by Fireman31
(Post 4098181)
Well, it was 2 qts. low. Now I know why I don't ever member seeing a rad. cap under the hood. There isn't one.
The green Prestone has been compatible for the past year or two. Just check the label.
