Coolant overflow hose
Old Oct 10, 2004 | 09:50 PM
asull79's Avatar
Question Coolant overflow hose
Got a question guys I installed a FIPK tonight and while I was putting the shield in I noticed a hose was not connected to anything it is the one that is coming off of the coolant tank and it is the hose that is right under the cap to the tank my question is does this hook to anything or does it stay off I was not sure I looked around and could not find any hookups.
Old Oct 10, 2004 | 09:53 PM
its not attached to anything on mine. i assume if too much pressure builds it will overflow out of that hose or something like that
XLR8NSS's Avatar
Adkoonerstrator
I'm pretty sure that is just a vent tube that you're talking about. It's just a little rubber hose right? Maybe like 1/2" in diameter?
Old Oct 10, 2004 | 09:57 PM
asull79's Avatar
Cool I figured it wasnt attached to anything since I could find any connections appreciate the help guys. Has anyone installed the VR stack with a K&N FIPK i tried to but it was a pain any tips to get it in there.
Old Oct 11, 2004 | 07:47 PM
2001GMC's Avatar
I put the VR stack on a AFE set up and imagine that you are having the same problem I did...the VR sticks out of the TB too far and your tube won't fit, right? If that is your problem, I have a fix that is working like a champ for me. I took a piece of 60 grit sandpaper and layed it on a very flat surface and took the face of the VR that sitcks out of the TB and swirled it around in circles until I had "machined" it down unitl I had ~1/16" left sticking out of the TB, making sure that it was even all the way around. I then slid the intake pipe down and in front of that puppy, made sure the pipe was centered, clamped everything down and was good to go. Hope this helps.
Old Oct 11, 2004 | 10:31 PM
asull79's Avatar
I notched the fan shroud last night and got it to go on so im good to go but man I hate the stupid clutch fan that thing is gone as soon as I have some dough to throw around.
6.0l RST
Nov 23, 2015 11:30 AM
bearden86
26
Nov 15, 2015 03:58 PM
Gadgetized
Oct 22, 2015 09:06 AM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
