Coolant guage temperature. What is your temp. range?
Old Jan 15, 2006 | 06:34 PM
BLASTER's Avatar
Default Coolant guage temperature. What is your temp. range?
Hook up my water temperature guage and the max it read was 180-185 F
I have a crankshaft fan so it runs all the time.
Does it ever get any hotter than this? This was idling/driving. I have the sender in the passenger head. Much easier than under the starter. Especially on the truck.
I know the guage is good cause I tested it in my car since I have that all hooked up already.
Old Jan 15, 2006 | 07:51 PM
negativeswitches's Avatar
stock thermostat is 187ish aint it?
Old Jan 15, 2006 | 08:05 PM
budhayes3's Avatar
PT's Slowest Truck
I used to see temps between 195*-197* on my AutoXray scan tool, with the factory stat and fan clutch. On a real hot day, after beating the **** out of it, temps would climb as high as 203*, but come back down around 195 pretty quickly...I thought that the GM factory stat was a 195*
When I swapped in a 180* stat, my temps would range between 188*ish and up to about 195-197*ish...still utilizing the factory fan clutch.
Now with my 05 e-fans, my temps average around 175*ish (fans come on at 180* and off at 173*...have them set to come on both at low speed when turn on temp is reached)
Old Jan 15, 2006 | 08:10 PM
i know my s-10 stock was 195 but it's a 2.2 4 banger
napa guy said my stock one was 187 or something weird like that
just relaying what they told me
but i have a 99 and them 1st years builds can be whacky
Old Jan 15, 2006 | 08:16 PM
TarheelZ's Avatar
...I thought that the GM factory stat was a 195*...
Same here.
Old Jan 16, 2006 | 01:24 AM
BLASTER's Avatar
Don't know. Just figure my Fbody swings from 180-190 cruising @ a good speed to 210-220 idling/city driving/stuck in traffic. Think that the Fbody T stat is 195 and the fans don't come on till 220 or so.
Thanks. Then that makes sense.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
bearden86
26
Nov 15, 2015 03:58 PM
Lthompson
Oct 2, 2015 12:45 AM
sTNT971
Sep 26, 2015 04:22 PM
Lthompson
Sep 21, 2015 07:06 PM
