Considering 6.0 swap. Hold off on exhaust?
Old May 8, 2005 | 08:03 PM
RyPkr_99's Avatar
Default Considering 6.0 swap. Hold off on exhaust?
I had planned on getting an exhaust system after I paid off of my truck and last week was the last payment. I've also been entertaining the idea of a 6.0 longblock swap. I won't likely be doing headers with this so the exhaust will still fit as I would be using the current manifolds. The exhaust I'm thinking about having done is just 2 single chamber flowmasters, (I know they flow like shat) probably no H or X pipe and it dual it straight out the back.
My biggest concern is this... If I go and have a new system all welded up and I decide to do a motor swap will end up having to take the sawzall to the pipes? Or can it all be left in tact and not bothered with?
Old May 8, 2005 | 08:08 PM
they wont't weld them to the manifold's and at most shops they use clamps unless you request weld.I've debated the same think however I chose to do it after the swap because I want a larger dual exhaust then my current motor will handle. that was just my take on it.
Old May 8, 2005 | 08:11 PM
RyPkr_99's Avatar
No, of course they won't weld the pipes to the manifolds. And I don't want a clamped system, welded or nothing. I was just wondering if I choose to do the swap. Could I just unbolt the studs holding the pipes to manifolds, pull the engine, swap manifolds to the 6.0, and drop it in with the old exhaust still in place? I know generally you're supposed to remove the exhaust system but I don't really see why you couldn't do it like this.
Old May 8, 2005 | 08:27 PM
litreddevil's Avatar
Banned
I don't know why you generally have to take the exhaust down but no you don't and just make sure put the right size pipe.
Oobray
Jun 13, 2022 03:38 AM
ARC
57
Feb 21, 2022 10:54 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
