Comp. change, head gskt. thickness ??
Old Mar 31, 2005 | 01:08 AM
RGMEPP's Avatar
Default Comp. change, head gskt. thickness ??
Soon to have the 6.0 LQ9 down for a cam. head gasket thickness is going down from .054 to .032. Before I go digging through my books, is anyone out there a wizard on this kind of stuff ?? How nuch increase in compression ??
Old Mar 31, 2005 | 03:10 AM
Grey Silver's Avatar
11 Second Club
The pistons in a stock LS1 motor come out of the hole about .010. With a .032 head gasket the piston will hit the head. If you want more compression shave the heads or put some pistons in it.
Old Mar 31, 2005 | 07:50 AM
Green Thunder's Avatar
Here is a compression calculator to help you with the math..
Compression Calculator
Old Mar 31, 2005 | 07:54 AM
Yelo's Avatar
If the piston comes out .010 and the gasket is .032 then he has .022 clearance between the piston and the head....I think this is a little close for comfort myself and that he will REALLY need to check p/v clearance VERY CAREFULLY but the piston won't hit the head itself
Old Mar 31, 2005 | 12:07 PM
11 Second Club
No it won't hit untill you start it up. The clearance you refer to is called quench. Do a search in the internal engine section and you'll figure it out.
Old Mar 31, 2005 | 07:40 PM
Yelo's Avatar
How can a motor with .022 clearance between the top of the piston and the bottom of the head have piston/head interference ???
Maybe I'm just dumb here but it seems to me that even when started that there will STILL be .022 clearance.....even with heat expansion there should still be room, WHY would ANYONE make a gasket that would CAUSE the piston to touch the head ????
Old Apr 1, 2005 | 02:32 PM
BigTex's Avatar
It all depends on the duration of the cam and valve timing. If the valves aren't open too far when the piston reaches the top, then there isn't an issue.
I do agree however that the .008 negative deck height with a .033 gasket thickness is a pretty tight quench.
Old Apr 2, 2005 | 06:09 PM
11 Second Club
[QUOTE=BigTex]It all depends on the duration of the cam and valve timing. If the valves aren't open too far when the piston reaches the top, then there isn't an issue.
Let's forget about the valves for now, we can always cure that problem.
Are you saying that the piston will not hit the head at .022 quench on an LS1 motor?
If anyone decides to try this please be sure to let me know because I would like to hear how it works out for ya.
Oobray
Jun 13, 2022 03:38 AM
Noah Burns
Sep 7, 2015 05:50 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
BennyB
Aug 1, 2015 08:48 AM
