comp cam 212/218?
Old Jun 11, 2004 | 11:03 AM
twobit's Avatar
Default comp cam 212/218?
Could you get by without any tunning with this cam in a 5.3? 212/218/ 553/563 114+4 thx
Old Jun 11, 2004 | 11:09 AM
FILE's Avatar
I know the lower lift 212/218 you can go in without tuning. Not sure on this one thought. You might get away just by rasing the idle to about 650rpm.
Old Jun 11, 2004 | 11:14 AM
Maybe,but you will not get the upper RPM benefits. I believe that is too much lift for stock springs though.
Old Jun 11, 2004 | 11:17 AM
FILE's Avatar
Yeah.. he won't even get by with the ls6 springs. He will need the Comp 918's or comparable.
Old Jun 11, 2004 | 11:23 AM
14 Second Truck Club
Clint, are you thinking about switching?
Old Jun 11, 2004 | 11:29 AM
BigTex's Avatar
I think it would be ok, but would run better with some sort of tuning. That cam will probably have a similar idle as the low lift version since they have the same amount of overlap in the .006 - .050 range.
Old Jun 11, 2004 | 11:30 AM
Its a small enough cam you dont need tuning. Just swap the springs and raise the idle to @ 700rpms. From tuning you may get another 10rwhp though.
Old Jun 11, 2004 | 11:34 AM
twobit's Avatar
Thanks for the input everybody! Richard(99SilverdoSS) you have a pm.
Old Jun 11, 2004 | 05:33 PM
hink9's Avatar
so.. what if you have an 03 with throttle by wire, how can you raise the idle, no to hijack or nething just curious
Old Jun 11, 2004 | 05:40 PM
The tiny hole in the TB blade, just drill it out in small incriments till the idle is where you want it. Just dont push it over 1/4". Mine is set at 750rpms now, and the hole is about 3/16. Maybe a tiny bigger.
Just dont go nuts and drill it to big the first time or your SOL.
